Question about Home
The hottub keeps kicking the circuit breaker off.
The jacuzzi hottub keeps kicking the circuit breaker off. Can't even turn the light on without the circuit breaker kicking off.
  • 299 Answers
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
Posted on May 02, 2010
On jacuzzi, circuit breaker trips when turned on. What could be the problem?
Is it simply a circuit breaker, or a safety switch as well?
If just a circuit breaker, something is causing a too-high electric current flow. If a safety switch, there is a fault to ground somewhere in the jacuzzi.
Either way I would not get in it or turn it on until an electrician has checked it over. With any device where you sit in the water, you need to have high confidence there are no electrical faults waiting to zap you. I'd call a jacuzzi outlet and ask them for the name of a knowledgable sparkie.
That's about the best we can tell you at this range.
Nov 01, 2016 | Electrical Supplies
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Siemens breaker just for overhead lights in bathroom and hallway Why does it buzz for a second then TRIP off?
You say the breaker supplies power to just one or two lights? And no outlets, fans, attic circuit? Map out all affected electrical boxes.
Move wire from suspect breaker to another same-size breaker and see what happens.
Move wire from the other breaker a to newly installed breaker, to check if breaker is main suspect.
Open each switch and outlet box affected by suspect breaker.
Disconnect power at light switch, and see if breaker still has problem.
Unplug all things from outlets on circuit.
One by one, check each electrical box for burned wires and loose wires.
Use nose to smell for burned condition.
Add a comment and update as you progress through troubleshoot.
http://waterheatertimer.org/Troubleshoot-household-electricity.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 22, 2012 | Electrical Supplies
My Jacuzzi H522 will not turn off sometime without shutting the breaker off. It has even turn itself on a few times so we leave the power off
sounds like you need a new temp sensor on your tub. if it is not heating and running all the time even though it is calling for heat - then the sensor is bad.
you can find a sensor here Bath Parts Plus
Jan 22, 2011 | Jacuzzi Mito, 6 Whirlpool Bath - H522
Jacuzzi Bathtup pump issues
buzzing sound on a motor means it has almost burned out. you will need to replace the pump.
May 12, 2010 | Jacuzzi - Bathtub - Alcove - Navona -...
The Lights circuit breaker keeps trips without load
try a new breaker, they do wear out over time
Feb 08, 2010 | Electrical Supplies
Jacuzzi hot tub, aero select. pops circuit breaker as soon as switch is thrown. I disconected both motors and panel. still blows. Unit is about 8 Years old. Is there anywhere I can get a schmatic or any...
Your Jacuzzi should be connected to a large GFI breaker. If it pops as soon as you turn something on, there is an imbalance between the legs supplying the power to your device. When my (small "J") jacuzzi (at about age 15) did this, I discovered a small leak that had dripped onto the circuit board and had left a deposit causing a "short". I was able to clean the deposit off of the board physically, I fixed the leak and return my tub to service.
The GFI is very sensitive and for good reason. It protects you from dangerous electric voltages, even though the danger is low.
Oct 04, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
How to wire up a spa or jacuzzi
Breaker, even GFI's are designed to trip at 135% to 600% over there load rate, so not to scare you but it depends more on the wire used from the main panel to the dryer/hot tube then the breaker. A GFI's claim to fame is the speed at which it will trip if voltage is detected on the ground side of the breaker. So to answer a question with a question, Can you overload a GFI without tripping it, Yes you can, just be careful the life of your hot tube motor and heater could be in danger if you overload the circuit.
Mar 24, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Home Logo
373 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
