Question about Pentair 3hp Whisperflo Pool Pump In - Ground
Zodiac Clearwater - NO FLOW
I am trying to get my in-ground pool ready for swim season by my Zodiac Clearwater is currently showing in NO FLOW staus. How do I correct this problem? What would cause this?
    Top Expert:
  • Pentair Master
  • 7,206 Answers
If filters ok check sensor and cell
Posted on May 08, 2016
3 Suggested Answers
mshill172
  • 20 Answers
SOURCE: need operational manual
the manual is available at this web add, thanks be sure to leave a good rating.....
http://www.novem.com.mx/mkreepy.pdf
Posted on May 12, 2009
jharwell668
  • 640 Answers
SOURCE: My zodiac g3 does not cover the entire swimming
One of the most common problems with these pool cleaners is the hose. If the hose is not long enough, it will not cover the entire pool. You might need additional hose. Also, make sure that your hose is weighted correctly and the water pressure is correct.
Posted on Oct 12, 2010
What is the air pump in the zodiac clearwater ozonator
This ozonator is no longer manufactured. It was made for larger spas with a volume of 1,000-1,500 litres. As the Zodiac Spa Ozonator, when it was manufactured, had its own internal AIR pump to add ozone to the spa independently of the other equipment - 24/7. Ozone is an extremely powerful oxidizer and as an added benefit, ozone also kills viruses. When a unit has an auxiliary air pump, it can always add ozone, even if circulation equipment is off!
Mar 16, 2015 | Zodiac Pool & Spa
I have a jandy ray vac pool cleaner that just goes in circles in the deep end of the pool.
look at instruction manual there is a setting you probably have to set
Jun 01, 2014 | Pool & Spa
Lm2 unit. No chlorine output. no flow light is on but dim. super chlorinate light is on.
check voltage at cell if high cell might be shorting out or transformer going out
May 20, 2012 | Zodiac Clearwater Lm2-24 Complete Salt...
My zodiac is pulsating, diaphragm is clean but it stays in one place>??
It sounds like you might need to adjust the pool cleaners water pressure. You need to use your flow gauge and check it. Keeping the hose submerged, attach the flow gauge to the hose and turn on the pump. Verify that the red indicator in the gauge (viewed from the side) is at the Number 3 setting. If you flow is low, verify that valves controlling the suction lines are in the correct position.
Oct 20, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My zodiac g3 does not cover the entire swimming pool
Aug 08, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I have the zodiac g3 i hear it pulsating but i looks like it has too much suction and it gets stuck and does not move how do i adjust it
You need to use your pool cleaners flow gauge to test for proper flow. Keeping the hose submerged, attach the gauge to the hose and turn on the pump. The red indicator, when viewed from the side, should be at the 3 setting. If the flow is too low, check and clean the pool filter and baskets. If the flow is too high, verify that valves controlling the suction lines are in the correct position, change your flow setting on the Flow Keeper valve, or open the main drain slightly.
Jul 03, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac clearwater LM3-15
Just found the instructions for this at this address
http://www.zodiac.com.au/media/25135/zodiac%20lm3%20owners%20manual.pdf
worked beautifully....good luck.
Sep 07, 2008 | Zodiac Nature 2 Cra30 Replacement...
Pentair 3hp Whisperflo Pool Pump In - Ground Logo
213 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
