Question about Ricoh Aficio 1022 All-In-One Laser Printer
Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Hi after moving our Infotec IS2220D to a new place we still get this error SC551 ( Pressure roller thermistor open)
The machine only gots 8000 pints on the counter but has no warranty. The guy from Infotec wants to change the Power supply (and for that he charges 750€ +VAT :D ) I'm sure the PSU is ok and he really doesn't know what he talks about.
Can somebody help me reset this error or solve it ?
Thx,
  • Milan D Apr 02, 2008
    HI, can you please be a little more specific?
    What are clear modes 1.07and 7
    DO i start the machine while pressing and holding the buttons 1,7,0,and clear/stop all togheter?
    The only function still working is nthe system button (dimaond/123 in sqaure)
    Normally it should be possible to reset this error and maybe the machine would work after that.
  • Anonymous Mar 20, 2014
    sc571 error olease solve
  • 87 Answers
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Posted on Apr 01, 2008
  • Dale Richards
    Dale Richards Apr 02, 2008
    you said -->
    No press them in sequence, and follow the instructions, regardless of how the machine is responding. The clear modes, is a yellow button, clear/stop is the orange button, 1, 0 ,7, are numeric keys.
SC551 error on Infotec IS2220D same as aficio 2020D
it must be a small damage in capacitors in power supply
Mar 25, 2008 | Ricoh Aficio 2020D Copier
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Our Gestetner MP 2000Le have an error sc551 and we can't troubleshoot it using the (Clear mode+107+hold the Clear/stop button) ..can you pls. advice us for other options ? tnx
Enter in the service mode: Clear(yellow key) 107 press/hold Clear/Stop more 4 second,enter in the SP mode open the front cover ,turn OFF the copier,wait 1-2 minutes close the front cover and turn ON the copier.
Jan 30, 2013 | Ricoh Aficio MP 2000 Black and White...
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Fault SC546
SC-546 is "Warm-up" error, suggests that the fuser is NOT reaching 160' within standard warmup time.
You might be able to take out the fuser, remove fuser cover, remove carbon buildup from thermistor.
I had to change our fuser at 180,000 copies (service is at 120,000)
Jan 12, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Printer/fax problem
whats the make of the copier ie: Ricoh, Canon
Jan 09, 2008 | Office Equipment & Supplies
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Ricoh Aficio 1022 All-In-One Laser Printer Logo
2,125 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
