Question about Nintendo Wii Remote Controller
The hand that selects everything on the wii won't show up. you can still press other buttons such as the power on the remote and that will work, but the hand won't appear at all.
    Problem Solver:
  • 9 Answers
This is because u might havent connected the sensor. So connect it then place it up the t.v.
Posted on May 01, 2010
Can't concetting to the internet.
According to ehow, you should do this:
Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • Press the "A" button on your Wii controller to continue from the warning screen.
  • Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • Click the "Wii Settings" box on the right.
  • Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • May 08, 2011 | Nintendo Wii Console
    We can't get two player mode to work in Wii Star Wars. We press the + on the 2nd controller and the player will not drop in. The blue lights show the controller is working. Why is this not working?
    Press the home button, select Wii Remote settings, select reconnect, and press the 1 & 2 buttons at the same time on the Wii Remotes you want to connect. - I just did this and it worked a treat.
    Feb 01, 2011 | LucasArts Entertainment Company LEGO Star...
    Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
    Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
    There are two different modes of synchronizing (syncing):
    • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
    • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
    Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
      Standard Mode Synchronization
      Note: Make sure you have placed batteries in the Wii Remote (how to).
    1. Press the Power button on the Wii console to turn it on.
    2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
    3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
      Go to the Next Step (Playing Game Discs) >
      One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    3. Select the Wii Remote Settings option from the Home Button menu.
    5. Select the Reconnect Option.
    7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
    Jan 27, 2011 | Nintendo Wii Console
    How to recieve internet connection
    Hi. Here are the procedures on how you conect Wii to the internet
  • 1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • 2 Press the "A" button on your Wii controller to continue from the warning screen.
  • 3 Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • 4 Click the "Wii Settings" box on the right.
  • 5 Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • 6 Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • 7 Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • Sep 12, 2010 | Nintendo Wii Console
    My wii remotes will not show the little hand
    Synchronizing Wii Remote: Press the power button to turn on your Wii console. Remove the battery cover on the back of the remote . Change the two AA batteries. Open the door on the front of the Wii console and press the RED (SYNC) button at the same time push the RED (SYNC) button in the battery area of the remote. Thats all now have fun.
    Aug 25, 2010 | Nintendo Wii Console
    Wii will not connect to the internet. how do we get connected?
      Connect a Nintendo Wii to the Internet through a Wireless Router
    1. Step 1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
    2. Step 2 Press the "A" button on your Wii controller to continue from the warning screen.
    3. Step 3 Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
    4. Step 4 Click the "Wii Settings" box on the right.
    5. Step 5 Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
    6. Step 6 Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
    7. Step 7 Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
    Jun 25, 2010 | Nintendo Wii Console
    Sensor Bar
    The senser bar can ONLY be used if it is ON TOP of the TV OR BELOW it.
    Dec 31, 2009 | Nintendo Wii Console
    Made a loud noise and then wouldn't turn on t.v.
    you need to reset the configuration and it also happens when the systems been on for a long time unplug the main power supply for 30 mins and try again. hope this helps and also try and clean the disk and let them dry.
    Lites flash on remote and thats all
    Your Wii must be on to be able to Sync the controllers.
    Press the power button on the Wii, then press the red sync button located behind the SD slot door. Once this button has been pressed, locate your controllers, take off the battery cover, and press the red button inside the battery compartment. The blue lights on the front will flash a few times, a chime will be heard, and your controllers will now function with that Wii.
    Every different Wii you use these controllers with, you must sync them every time to that other Wii
    Jun 21, 2009 | Nintendo Wii Console
    Nintendo Wii Remote Controller Logo
    64 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
