My computer won't stop rebooting. Hello and thank you for reading, My computer won't stop rebooting itself regardless of what hard drive I plug in, it gives me the "Windows didn't start ... please use the up and down keys to choose .... safe mode, safe mode with network, command prompt start windows normally, last know configuration" Regardless of what I choose it's start to load then there will be a beep and it'll be as if I just turned on the computer, the bios info will be there and I will get lead back to the windows didn't start screen.
  • 1 more comment
  • thejzone May 01, 2010
    Wow, thanks for the quick response!
    I just want to be sure it's not a hardware issue, because I have plugged in a few drives with Windows 7 installed and it does the same thing each time.
    Okay, I just want to be sure, because each hard drive has a separate windows installation on it.
    I'll go out an buy a copy of Windows 7 and try this out later if you think that all I need to do is reinstall.
  • thejzone May 02, 2010
    Thank you, that fixed the problem!
  • 6,487 Answers
Base from the description of your problem its clear that your operating system is already corrupted and needs to be repair or better to do a clean installation of the operating system, in order for you to repair the operating system you need a XP installation disc and then load that from there you will be able to repair the system or do a clean installation.
Posted on May 01, 2010
  • Mark Gil
    Mark Gil May 01, 2010
    Nope this should be corrected by repairing the system or doing a full format on the drive and installing a fresh copy of operating system on it.
  • Mark Gil
    Yes if you have a copy of windows 7 that will be good, then just leave one hard drive connected to the computer and then do a clean installation of windows 7 to it.
My book hard drive won't read
1. First try to use another usb cable. If it still won't work.
2. Try plugging it into another computer. If it still won't work.
3. Try removing the hard drive from your BOOK HARD DRIVE, and plugging it directly to your computers desktop SATA socket using a SATA cable. If it works, backup all the data of your BOOK HARD DRIVE and then delete the partition and make a new partition and then format it.
Jan 25, 2013 | Computers & Internet
Why won't my dell laptop cannot read the primary internal harddrive?
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 08, 2012 | Dell Inspiron 1545 i15-143P Jet Black PC...
My hard drive quit showing up on my mac desktop and i am not able to access any of the files. the red light still turns on when i plug it in but thats it. i tried plugging it into a pc to see if it would...
It sounds like the hard drive died.. If it won't show up on two different operating systems, then it's more than a simple computer reboot. You may want to try a local repair store and see if they have any luck backing up the drive.
Jun 01, 2011 | SimpleTech SimpleDrive 160 GB External USB...
My external La Cie 500Gig HDD has worked well for 3 years or more. Now when I connect it (via USB as aI have always done) ..The following happens: 1 I see the drive usually but not always under "My...
your drive has failed at either the power supply level or internal hard drive level.
First, please verify your power supply. When plugged into the power outlet, it should be silent. A defective power supply will hiss or have a high pitch noise to it. If it is defective, replace it and check if the issue is resolved.
If the power supply is silent, one or both of the internal hard drive is failing. If no data is needed, you can either replace the defective one which you will have to isolate by connecting the internal hard drives to a computer or with another enclosure and running a block scan software like hdTune which is free to download. The other option would be to scavenge the healthy drive and use it in another enclosure or inside the computer directly.
If you need the data and the problem was not the power supply, you will need to contact a data recovery center.
Regards,
Jan 07, 2011 | LaCie Big Disk 500 GB Hard Drive
My computer won't stop rebooting itself. Hello and thank you for reading, My computer won't stop rebooting itself regardless of what hard drive I plug in, it gives me the "Windows didn't start ......
May 01, 2010 | Computers & Internet
Hello and thank you for reading, My computer won't stop rebooting itself regardless of what hard drive I plug in, it gives me the "Windows didn't start ... please use the up and down keys to choose...
When you say "regardless of what hard drive I plug in" worries me.
If you didn't install windows on the hard drive you're using while it was in your computer it won't work. Windows needs to see all devices as it is installed.
My best guess for you is to install windows again onto a hard drive.
Failing that you could download one of the linux O/S, say UBUNTU, and that will load onto your pc without installing so you can look at the data on the HDD's.
Finally there's the ultimate boot for windows CD which loads a windows shell onto your PC without installing and provides loads of diagnostic tools.
Both the last two items are freely available to download at the end of a GOOGLE.
Laptop powers down 5 seconds after turning on
Straight forward method would be to download Microsoft Diagnostics and Recovery Toolset from microsoft.com, write it to a bootable CD. Make your Laptop bootable from CD drive (ie. is change the sequence of booting. At present it will be booting from Hard disk.) Boot from the CD you just created. Check what is the problem. And possible repair can be done. Check this link.
http://technet.microsoft.com/en-us/library/ee460910.aspx
But.. may be a little difficult.
And while I am at this, be careful when you take out a hard disk from one laptop and insert it in another laptop. Even though it is from the same manufacturer, it may not be compatible.
Another easier option would be to get hold of a desktop computer that is working. Get a cable which can be used to connect your laptop Hard disk to the desktop. A desk top allows multiple drives. This way you can get the laptop HDD as a seperate drive in your My computer, (like you see a pendrive or a CD drive. You can try reading this drive and copy content to the desktop. And burn it to a CD. May be a little more easier. If you have difficulty in reading the Laptop HDD, you can download one or the other programs that helps in reading corrupted drives. Good luck.
Jan 28, 2010 | Computers & Internet
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Western Digital hard drive problem
Ok.  I have a WD 500 and I have ran into similar problems.  First, shut your computer down.  Unplug the hard drives USB cable and the power cable.  Wait for about 2 minutes.  Plug the USB cable into the computer, plug the power cord in...wait for 30-45 seconds and then start your computer.  That hopefully should solve your issues.
Mar 01, 2009 | Western Digital My Book Essential Edition...
Segate FreeAgent 750GB external hard drive
my iqube extenal hard drive is not working was dropd down, I have tryed plag and play and it shows the light and fun inside working and when you staart uyou can ear like its start but stops after few seconds
Oct 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
