Question about Maytag MFF2558VEA Bottom Freezer French Door Refrigerator
Ice maker either doesnt work on my Maytag MFF2558VEA or when it does it produces too much ice. every time we open the freezer, ice pours on to the floor.
    President:
  • 1,218 Answers
Good day,
There is a wire shut off arm that on the front extends into the control module of the ice maker.
If it's in place then the problem is the ice maker itself.
The control module can be replaced but isn't very cost effective. The ice maker should be replaced. It includes the module as well as many other components that can fail.
Posted on May 01, 2010
Maytag psd245ogr refrigerator, no water, no ice. Started with hollow cubes and over time smaller and less cubes. Finally, no ice in freezer and no water or ice at the door dispenser.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Maytag MSD2454G Side by Side Refrigerator
I have a ICE2O maytag refrigerator that is 2 years old my electricial board was bad and I had it replaced. The part number is 1290710. Now my ice maker does not work. I have water but no ice. I have...
f there There's no ice Please read this entirely to assist you in troubleshooting this problem. If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If too cold then the ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 01, 2010 | Maytag Refrigerator Icemaker Ice Maker...
Ice maker not producing ice. no water flowing to ice making unit. water coming out of dispenser
You have to hook the icemaker up to the electrical circuit powering your refrigerator. Make sure wiring is correct. Some time it won't work if there is a loose connection.
samsung fridge freezer
Oct 30, 2010 | Maytag Refrigerators
My refrig stop making ice after I changed the water filter. I had the filter out for about 3 hrs, would this cause the problem?
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 28, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
My maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Mar 17, 2010 | Refrigerators
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Ice machine will not even start the ice making process. can get water out of the door with good presure but no ice
You either have a bad ice maker or a bad water valve. It really depends on what your model # is and brand.
Mar 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Maytag MFF2558VEA Bottom Freezer French Door Refrigerator Logo
114 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
