Question about MSI 845GLMS-L (MS-6754G-020) Motherboard
Will not post
My MSI 845GLMS-L will not even post. All I get is a prolonged 'beep' (last about 2 sec.) every 2-3 secs.
  • 655 Answers
Yaa this type of beep means your RAM is missing.
to confirm this, just remove your RAM and boot, you will find the same beep.
if this the your case, try thsese:
1...clean the RAN connection point, and insert it again, then try too boot. if not.
2....change the RAM in another slot and try to boot,
if no luck then, change the RAM..
Thanks
Iqbal
Posted on Mar 25, 2008
SOURCE:
PS3 won't reset
are you trying to get to the safe mode menu?...if so unplug for 1 minute...replug...hold power button (beep) 5 secs next beep is 1...next beep is 2 after 5 secs and power off. let go of button...repush power button(hold)...(beep)...then beep again after 5 secs...then 2 fast beeps...let go of power button. it will ask you to connect your USB to your controller then push the PS button on your controller. you should be in the menu for safe mode.(research your options there thru sony and understand what they are first before running them!)
Nov 18, 2013 | Sony Playstation 3 (PS3) Console
I need the manual for my motherboard ...o factory name on the board ..just ms 6745 ver 1.0
The manual and updated drivers for your board is in this link....
http://www.msi.com/product/mb/845GLMS.html
A thank you reply will be appreciated!
Hope that helps you out.
Thanks for asking FixYa!
Jul 30, 2011 | MSI 845GLMS-L (MS-6754G-020) Motherboard
At switchon the mother board bleeps continously for about 10 secs takes a break 5 secs then goes bleep again for another 10 secs and repeats the cycle reapetedly until switch off. All drives have been...
It is a very real possibility as there are no beeps when it is removed, but that does not mean it is faulty, you could be getting POST beeps suggesting there is a fault with the mainboard, have it checked out with a local & reliable engineer who may be able to solve your problem.
Keith.
Aug 06, 2017 | Intel Server Board SE7501CW2 Motherboard
Battery on Samsung Wave does not last long even when the phone is not in use for a day, and does not last the day. Also can go down in a few secs. This happens even with internet off. Help!!!!
Hi there, this is a known issue with samsung wave, that's why samsung released an update that should prolong the battery power. So if you really turned off all the power-hungry apps and services (like internet, wifi and music player) then go for the update. It's a firmware update!
-Install Kies( can be downloaded from samsung.com) -Connect your mobile phone to your PC using the Samsung Mobile Cable -Run Kies, and it will guide you through the installation process
Feb 28, 2011 | Samsung Wave S8500 Smartphone
After starting my PC I only hear a peep
If you are getting long and short beeps it is possible that the graphic card on your system is not proper.
Either the graphic card is gone bad or it is not seated properly
Try to open the computer tower, disconnect the Graphic card and then see if it still beeps. If it does not beep after removing the graphic card try to reinstall the card and see if it is beeping. If the computer beeps even after reseating the graphic card then you will have to replace the graphic card.
Jul 19, 2010 | Medion M3 Composer 5100 PC Desktop
Packard bell l4 beeps on start up for about 5 sec then works ok would this be memory prob
When your computer starts up it runs a series of test called the POST (Power On Self Test). When test is complete it beeps to let you know if the hardware is OK or if there is a problem. One beep means the hardware passed the test with no problems. If your getting more than one beep you'll have to check with your manufacture to find out what it means. Go to their web site and search "POST error codes", this should give you the information you need.
May 20, 2010 | Packard Bell Easy One Silver 2101 Notebook
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Need to set the clock
press CLK button to temporily display clock to set clock press clk > 2 sec use the left and right arrow to set hour and min
Aug 22, 2007 | Jensen KDC-9520 CD / Cassette Player
MSI 845GLMS-L (MS-6754G-020) Motherboard Logo
99 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
