Question about Karcher K 593 M Electric Pressure Washer
No pressure handle leaks .have no pressure
    President:
  • 1,033 Answers
The handle needs replacing, usually these only last 1-2 years, rubber o-ring breaks down in the handle, it can be replaced but a good chance it will still leak. You won't have good pressure until the leak is fixed. I would say the pump is doing it's job. I just replaced a handle on my electric washer, which was doing the same thing yours is.
Posted on May 01, 2010
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
Oct 17, 2014 | Campbell Hausfeld PW135000AV 1350 PSI...
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Dirt devil1600 pressure washer leaking where the 2 handle parts join together.
    If the handle parts are screwed together, get some plumbers tape. Wrap it with the tape at least 5 or 6 times. Screw together. If the 2 handles aren't well machined give it more wraps. You could also use silicon pipe sealer but it doubt the machine is that close of a tolerance.
    May 10, 2014 | Garden
    What are the components in the handle of a Ryobi RHP 410 pressure washer?
    Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thankyou. ``
    Jan 28, 2012 | Ryobi Garden
    Fixed leaking faucet, now handles leak at the base & the water pressure is low
    No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
    Nov 23, 2011 | Plumbing
    I have a Karcher 110 pressure washer and when switched on to jet wash the water is coming out of the handle and just trickling out of the jet nozzle please can you help. Thankyou Brian Hills
    Which part of the handle is water leaking from? It could be that the hose connection into the gun is not fitted properly. Otherwise it could be that you just need to replace the handle.
    Feb 28, 2011 | Garden
    HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
    On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
    Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
    Installed a new 88976 handle but still have a leak
    replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
    Aug 31, 2009 | Delta & Single Handle Shower Faucet
    Sprayer leaking from inside handle mechanism
    although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
    Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
    Karcher K 593 M Electric Pressure Washer Logo
    212 people viewed this question
    Top Karcher Garden Experts
    John Trevino
    andy just round the...
    Level 1 Expert
    Are you a Karcher Garden Expert? Answer questions, earn points and help others
