Question about Car Audio & Video
Hi-changed over my car stereo out of my hyundai coupe 04 today but now the new stereo will not switch on automatically when power to unit-resulting in cd etc starting from begining again-i removed a clarion dxz438r and fitted a cmr2000 stereo-i cant see any difference in wiring apart from my cmr block has no orange wiring-thanks
    Scholar:
  • 84 Answers
You more than likely have the red/yellow wire (coming out from the back of the radio) reversed. the orange wire is usually for the dimmer feature and is not necessary to hook up. The red wire needs to be hooked to an accessory wire (i.e. send power when you turn the car on and goes to ground when the cars off) and the yellow wires needs a constant power source (i.e. always on from the battery) the yellow wire lets the radio retain memory.
Posted on May 01, 2010
Testimonial: "thanks for your reply-i thought so but the 2 blocks of wires matched up so i could not understand why it never retained its memory etc"
1998 hyundai coupe
Yes.
The sending unit has constant power coming from the battery, so it will always give you a reading.
Dec 29, 2011 | 1998 Hyundai Tiburon
Remote control receiver unit were is it , and a pic of it to reset key fob on a hyundai coupe se 2000cc year 2002
This reset for key fob Hyundai coupe year 02 to 04
Turn ignition to position two
Press lock or unlock once
Ensure indicators flash once to confirm reset
This will enable fob providing you have no other faults
Good luck barry
May 12, 2010 | 2003 Hyundai Tiburon
1999 hyundai coupe 2litre automatic. does not appear to change into 4th gear and engine reving high
you may have lost 4th gear and need a major repair or new trans. but it could be just a faulty sensor (hopefully because it would be much cheaper)....... a mechanic should be able to tell you with a quick inspection......good luck
Feb 13, 2010 | Hyundai Motor 1999 Tiburon
Pioneer DEH-P3100UB + hyundai tiburon 2003 se installation... possible or not?? :S
it is possible to install any stereo in any car.
power,switched power,memory and the speakers.
some older cars had one speaker lead common grounded to the car.
todays stereos have a floating output,and you will short the amplifier if you hook up the speakers to that type.
make sure the speaker leads are independent of the body ground.
Sep 01, 2009 | Car Audio & Video
Hyundai coupe wont start
did you change your plugs and wires?
Jan 19, 2009 | Hyundai Motor 1999 Tiburon
Hyundai coupe r/h drive heater
hi from uk your heater fan problem is most likely to be what is known as the resistor pack sometimes called the reostat and is connected to fan motor case it has the wires for fan connected this unit operates rather like an elec hob controlling amount of heat if this simplifies it for you? speeds 1 2 3and 4 gives the speed selected on fan control knob not too difficult to find and diy a replacement? and not too expensive ? these units do burn out occasionally on most cars as they age hope this helps/inspires ?
Jan 08, 2009 | 2000 Hyundai Accent
Hyundai Coupe gearbox ( not car in product)
hi there! i was a master tech 4 hyundai, first of all has the atf fluid been changed and at the correct level. or have you had the multifuntion switch checked? please feel free to contact myself and i will advise you as required with my exsperience
many thanks
Dominic Hill
Dec 09, 2008 | 1998 Hyundai Elantra
My Driver's Side Window Won't Go Down
it could be the motor or the window switch, go ask a stereo shop if the can test your switch or to see if there is power going to the window motor
Sep 27, 2008 | 2004 Infiniti G35 Sport Coupe
2001 Hyundai Accent 2 door coupe stereo wiring diagram
should be on the back of the amp mine is
May 24, 2008 | Car Audio & Video
Car Audio & Video Logo
114 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
