Question about Onkyo TX-SR605 Receiver
Remote volume control difficult. Doesn't respond promptly or at all. Is there a way to fix this?
  • hankins1eng May 01, 2010
    All other remote functions are fine.
    Two years. Since all other functions work fine, age/batteries would not seem to be the problem. I can change the batteries to see if it makes a difference - worth a try.
I the exact same problem. Remote works fine except for the volume. So annoying. It's not the batteries and it's not out of range.
Posted on May 10, 2010
  • 787 Answers
Change the batteries. If, with new batteries, the behavior remains, then you may be out of range.
Posted on May 01, 2010
  • Tudor Valean
    Tudor Valean May 01, 2010
    Have you had it for a long time?
  • Tudor Valean
    Change them. If it still doesn't work as it is supposed to, then you need to replace the remote. The most used buttons on a remote don't last long and the circuit board gets damaged as a result of prolonged usage. These things happen but there is no other solution for it.
Bravia kdl52ex700 volume control doesn't work
Look for any jammed buttons on remote, any obstruction like a sticker or gum on the sensor on the TV. If you have such obstructions, the TV will respond only partially.
Aug 15, 2012 | Sony Televison & Video
The volume stuck on max volume and will not respond to remorol or side panels
Some buttons on remote or on control panel is stuck. Look for it and try releasing them. Remove batteries from Remote and try adjustment from control panel. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Insignia Televison & Video
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
The volume control works to decrease volume but is very difficult when trying to increase volume
This may be an issue with the button itself getting caught on the plastic bezel of the remote. Sometimes this happens when the remote is dropped or the plastic bezel is nicked.
My recommendation is to reprogram the device you are trying to control the volume of. This issue may occur when the incorrect IR code is programmed into the remote. Some IR codes may work intermittently and as rolling codes. Check the program and respond if problems persist.
Jul 27, 2011 | Logitech Harmony 890 LCD Remote Control
My volume control on my Aiwa surround sound system no longer responds to my remote controller. Everything else works fine using the controller
Assuming the physical volume control on the receiver still works I would say the remote's volume control is faulty.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 20, 2011 | Aiwa AV-D58 Receiver
RCA Home Theater RT2906 doesn't respond to Remote
Have you tried new batteries?
May 16, 2011 | RCA Audio Players & Recorders
Volume control on remote does not always work. Is there something under the button that wears out? How to get inside remote to repair.
Hi, it's easy to fix. Most time when a remote volume control buttons does not work, it's usually caused by dirt inside or water spilt on the remote control, And when the button inside has moist, it responds slowly and does not respond at all.
What to do is this, Open the remote control, you will see a panel inside that controls the button functions. Use a cloth to wipe the all panel inside and close it back. Your done!!!.
But if it still those the same way,that means the damage is beyond repairs, You willneedto get another remote...
Hope it helps.
Thanks for using fixya....
Dec 04, 2010 | Onkyo Audio Players & Recorders
Lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Apr 28, 2009 | Hitachi C21 F800S TV
RCA Universal Remote
TV Can Not Be Programmed on this remote. Sorry.
=> http://remotes.com/remotes/documents/RCA/257003.pdf
Oct 12, 2008 | RCA 257003 Remote Control
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
Onkyo TX-SR605 Receiver Logo
65 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
