Question about Technics Audio Players & Recorders
GN9 - Problem with the rhythm section buttons ( the 8 set keys starting with 16beat). When any of the keys are depressed only the 16 beat key lights up and works ( ie if you press any of the other 7 keys it defaults back to the 16 beat key. )
Essayez de réinitialiser l'orgue, vous l'éteignez, vous appuyez sur les 3 premières touches de rythmes en bas à gauche ( les 3 touches 16beat) en allumant l'appareil en même temps, initial s'inscrira sur l'écran.
Bonne chance!
Posted on May 26, 2008
Change oil light on
depending on if your buick has the DIC option, it could be 1 of 2 ways.
  1. Turn key to accessory (key on , engine off)
  2. depress mode button on the DIC display til you see "oil life left/hold to reset
  3. Hold set button down till it says 100%
  4. listen for 3 chimes
  5. start car and see if its reset, if not, it wasn't reset, repeat steps 1-4.
If you don't have the DIC option, then:
  1. Turn key to the "key on, engine off" position
  2. Depress gas pedal to floor slowly 3 times, make sure you get the 3 presses to the floor within 5 seconds.
  3. turn key off.
  4. see if the light goes off.. if not, repeat the steps 1-3
Dec 08, 2013 | 2003 Buick Rendezvous
How do i transfer patterns from one sr-16 to another?
There are two ways. 1st way is to use the tape out and a 1/8 to 1/8 cable connected to a tape recorder or computer. And use the send thru tape function. while recording. then on the second one reverse the cable. And use the tape in function. The 2nd way is to copy beat for beat in the quantize mode by hand onto paper, the reprogram each sound(beat) back into it.
Aug 18, 2011 | Alesis 16 Bit Stereo Drum Machine System
I have requirement of region code cracker for sony 3d E370
hi,
To make your BD player you need One for all universal remote control
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
Aug 08, 2011 | Sony Televison & Video
I have a Sony BDP S370 and I would like to make it region free for my DVDs.
hi,
u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free.
first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAll URC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
12. Press 00255
14. Hold the magic button until the red led flashes twice.
15. Press 994
17. Press 00095
19. Hold the magic button until the red led flashes twice.
20. Press 994
22. Press 00221
24. Hold the magic button until the red led flashes twice.
25. Press 994
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S370 region free
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
4. Next time you turn on the player it will be region free for DVD playback.
OK
Jan 13, 2011 | Sony BDPS370 BluRay Player
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
Rhythmic noise on passenger side of dash.
It sounds like you have an hvac actuator problem.It could be the recirculate actuator either way the system should be scanned and after replacement it has to be calibrated.
Aug 06, 2009 | 2004 Pontiac Vibe
How do i reset the maintenance required light after an oil change on my 2009 Toyota Tacoma?
1. Turn the ignition key to the “OFF” position
with the odometer reading shown.
(For details, see “Odometer and two
trip meters” on page 145 in this Section.)
2. Turn the ignition key to the “ON” position
while holding down the trip meter
reset knob.
Hold down the knob for at least 5
seconds. The odometer indicates “000000”
and the light goes off.
If the system fails to reset, the light will
continue flashing.
To reset the Maintenance Lamp turn the car key to ON (not start), set your odometer on mileage (not trip a or b), then depress and hold the button that switches from odo and trip then turn key off. Turn the key back to ON, while you are holding the button down you will notice the maintenance light blink and go out. Reset is complete and you are done.
These are available in your owners manual for the vehicle.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 14, 2009 | 2006 Toyota Tacoma
Ignition cylinder won't turn
I had the same problem in a 94' trooper. Basically the Ignition lock cylinder is wore out and you need a new one. Mine wouldn't turn past lock and no matter what I tried it wouldn't turn. You can go on auto zone and find the part, mine was about 61 bucks, it comes with keys and the ignition cylinder. The deal is that to get your new ignition cylinder in you have to get your original turned to off or acc I can't remember. You'll see with your new ignition cylinder that when you turn the key there is a button that can be depressed but only when the key is turned past lock and it also won't depress in start. First, disconnect battery and wait like 30 minutes. So, what you do is take a screwdriver handle and place it up against key and take some pliers or something and beat on it a couple of times, this gets the key in deep enough to where you can eventually turn it. I swear it will eventually turn, once there, take off the top and bottom plastic covers off steering wheel/unscrew electrical wires on back of ignition cylider and other side and you know the button I referred to basically you have to depress that with key in acc or off and it will slide out. If your having trouble finding the button look at new ignition cylinder in comparison to old one and you can see where the depressed button is on side closest to you, you'll see a little hole up on the side of housing that you can depress.
Mar 01, 2009 | 2000 Isuzu Rodeo
Rhythm is stuck
Maybe the input/output audio was set for thise particular levels.. Look to see it you can reset to default
Apr 01, 2017 | Casio WK110 Portable Keyboard
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Victor 1260-2 Calculator
120 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
