Question about Kirby Heritage II Vacuum
Where does the fan belt go? - Kirby Heritage II Vacuum
  • 438 Answers
Hi There,
The belt on your Kirby Hertiage is put on almost exactly like the video below. The only difference on your model is that the brush actually rests in the bottom plate itself rather then the bell housing like the generation.
You can follow the same step by step instructions as the Generation in the video below, just put the belt around the brush, and put the brush into the bottom plate. Then put the bottom plate with the brush inserted, and the belt wrapped around the brush loose in the middle, back into the fan housing. Then turn the square shaped belt pulley on the font of the bell housing to the red setting. After the belt has been turned to OFF, then you may put the front bell housing back onto the vacuum cleaner, and after securing it onto the vacuum, now turn the belt pulley in the front back to BELT ON position.
The video will help you tremendously understand where and how the belt works on your Kirby. Here it is:
If you have any questions, or need help putting the belt on your Kirby, please feel free to use the comment section here on the Fixya repair page, and I'll be more then happy to answer all of your follow up questions.
If this was helpful to you, please be so kind and rate my repair helpful, or leave me feedback. This is really appreciated by Fixya repair professionals, and is the main reason that repair experts continue to leave free repair support, rather then just answering the premium questions that customers pay for. Please work the system Fixya has put in place, it's greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Posted on May 01, 2010
No suction
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Mar 30, 2014 | Kirby Ultimate G Bagged Upright Vacuum
I had problems replacing the fan on my KirbyG4 but with the help of this site was finally able to do so. When I put it all back together and turned on, the motor was very weak and then stopped and I smell...
There are a couple of possibilities here. First, I hope you made sure the new fan spun freely after installation, if so, and if you re-installed the rest of the parts correctly, you may have the belt installation crank on the front of the agitator housing in the up position yet. This is when you've installed the belt over the motor spindle. After that you need to continue cranking the assembly on the front until it's all the way down. That releases the belt so it can run freely and turn the brush. If it's still in the up position, it has the belt locked and the spindle will rub against the belt making the smell and smoke. Also if you closed the metal bottom plate and caught the belt under it when you finished the installation, that will also keep the belt from turning with the brush.
Oct 22, 2013 | Kirby G4 Bagged Upright Vacuum
When the vacuum is turned on, it makes a HORRIBLE noise. I thought the belt was bad. Removed it, looks fine. Turned on the unit w/o the belt/roller brush. Same noise. I don't know what else to check. Help...
You have probably broken the motor fan. An out of balance fan creates a great deal of noise and vibration. Fans are inexpensive, but require a good deal of disassembly for replacement.
Mar 19, 2011 | Halo UVST Bagged Upright Vacuum
My kirby g5 is not picking up, there is no blockage, but suction has dropped significantly, what could be the problem?
Not to question your description of the problem, but are you sure the suction has dropped? Kirbys don't usually lose suction unless there is a mechanical or electrical problem. When you turn the machine on does it fill with air and expand? If so, then you probably have enough suction. If the bag doesn't fill and expand and your machine is extremely noisy then the fan may be broken and need to be replaced. If you see excessive sparking near the bottom of the handle then you may have a motor problem like stuck or too short carbon brushes or a bad armature. On rare occasions, with Kirby owners who live close to a beach area and vacuum large amounts of sand, the sand actually wears down the vanes of the fan enough to make it useless. To check the fan; first unplug your Kirby from the electrical outlet, remove the brush roll nozzle, slowly spin the fan/belt pulley while observing the surface of the fan, look for cracks or breaks. The fan vanes should be about 3/4 of an inch deep.
If none of the above fixes your problem, look at the brush roll and belt. If your belt has not been changed in the last 12 months, install a new belt. If this is the original brush roll, install a new brush roll.
May 18, 2010 | Kirby G5 Bagged Upright Vacuum
Th end of the shaft that come from the motor is worn out, and won't hold the belt well. How do I change it?
Thanks for the clarification. I have never seen this problem previously in a Kirby. I wonder if the belt keeps sliding off because it's been stretched out? After about 1-2 years, the belts on the Kirby will stretch out to a point where there can possibly slide off the motor shaft. Have you tried just replacing the belt on the unit first?
If you're sure that it's not the belt that may be stretched out, and you'd like to replace the motor shaft, you certainly may do this. The only problem with this is the motor shaft is not sold by itself as a separate part. The only way to purchase this motor shaft is to purchase the entire fan assembly, which includes a new fan, and the hardware necessary on the fan assembly.
Here's a parts diagram that shows you the motor shaft is sold only in a completely assembly:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/kirby-generation-parts-diagram.pdf
If you haven't already purchased the motor shaft, here's a direct link to the motor shaft and fan assembly on our website:
Kirby Generation Fan Assembly With Motor Shaft and Hardware
In terms of installing it, we've actually recorded a video repair on how to replace the fan assembly, which involves removing the motor shaft in order to get the fan off. Since you have to purchase the fan assembly anyways in order get the motor shaft, you may want to go ahead and replace your fan assembly at this time also. Even though your fan may not be broken, on Kirby's the fans can become coated with dirt and fine dust, which can sometimes lead to the Kirby exhausting a bad smell. If you'd rather not replace the fan, you may remove the motor shaft without disassembling the entire machine, you'll just need to secure the fan somehow so that the fan doesn't spin while you're using a nail to turn the motor shaft off.
Anyways, here's the video repair that we recorded. I hope that this helps you. If you found this helpful, please kindly rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair. This is really what keeps Fixya repair professionals continue to give free repairs online.
Here's Part 1 of the video:
Here's Part 2 on Replacing the motor shaft and fan:
If you have any follow up questions, I'd be more then happy to answer them for you, please just add another comment here on the repair page, and I'll be more then happy to answer any follow up questions that you have. Thanks again for rating the repair, I greatly appreciate this.
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
My Hoover upright vacuum has gotten very loud. I have checked the roller, belts and hoses but I haven't found anything. What could the problem be? thanks
Most Hoover uprights are a "fan first" design, meaning that all dirt enters the motor , hits an impeller fan and is blown from there into the bag. You will need to open the vac, remove the belt and two C shaped clamps holding the motor in place and remove the 4 screws holding the fan cover. Look for a broken or damaged blade on the fan. It is a threaded fan and can be purchased at most vac shops. Reassemble in opposite order.
Post back to advise what you find
Dec 13, 2009 | Vacuums
My fan belt on my hoover is broken,where is it located and how do i fit a new fan belt
Get a new belt, then remove the bottom plate. The belt goes around the brush roll and the motor shaft. If you don't see the motor shaft, then you will need to remove the top cover to get to it. The belt will stretch to go from the motor shaft to where the brush roll sits in. If this model has 2 belts, then the drive belt(flat) goes from the motor shaft to the bigger pulley close to the brush roll.
Aug 10, 2008 | Hoover Vacuums
How do i replace the fan blade assembly which are broken in my ureka model the boss thank you lorne
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=540001
Generic problem for all Vacuums
Posted by lmurray1 on Apr 23, 2008
How do i replace the fan blade assembly which are broken in my eureka model the boss
thank you
lorne
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 different models of the boss by Eureka – there is a standard old style upright that the belt that the belt would unscrew from the bottom of the motor and you would have to remove the top of the vacuum cover to remove the main motor and gasket assm, and then the fan has a reverse thread on the plastic fan and you would unscrew the fan after removing the belt pulley. Then you would screw on the new fan, belt pulley, replace the gasket and re-install the motor. If you have a new style with a side mount motor you would remove the top cover, the motor would be in there sideways, un-screw the motor, remove the silver tape around the fan housing and un-screw the fan housing – same as above un-screw the fan from the motor, there is a nut on the end of the fan holding that on – (remember, the fan has a reverse thread) re-install the fan. Then the fan housing, replace the silver tape, and then screw down the motor and replace the top cover, then you can test. As always free to contact your local vacuum dealer in your area in the yellow pages or contact your Eureka factory manufacturer listed below:
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
FAN PROBLEM???
There isn't any belts, and the fan wouldn't be rubber, so not sure what you are smelling. Maybe this picture will help you.
Dec 30, 2007 | Bissell 6700 Butler Revolution Bagged...
Vacuums Logo
119 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
