Question about Mintek MDP-1760 Portable DVD Player
Battery pak will not keep a charge.
I've charged the battery pak up and it will not charge. Where can I get a new battery pack for my Mintek 7" inch portable DVD player?
    Genius:
  • Mintek Master
  • 1,550 Answers
Check on Radio Shack maybe there you find something
Posted on May 01, 2010
Ndrive g800r battery charging
Li-ion battery packs in laptops have a circuit board that prevents overcharging. Unfortunately it also keeps count of the number of times the battery pack has been through a charge/discharge cycle and eventhough the batteries maybe still be good; IT keeps batteries from accepting a full charge and and that is why they will not keep a charge for as long as they did when new. Also if any battery in the pack goes bad it effects the whole pack because of the way they are assembled.
May 19, 2017 | Computers & Internet
Tip
Mintek Portable DVD Player Battery Recall
Mintek Recall Hotline: (866) 709-9500
CPSC Consumer Hotline: (800) 638-2772
CPSC Media Contact: (301) 504-7908
CPSC, Mintek Digital Inc. Announce Recall of Portable DVD Player Batteries WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Portable DVD player battery packs
Units: About 116,000.
Manufacturer: Mintek Digital Inc. of Anaheim, Calif.
Hazard: The battery can overheat and explode while recharging, posing a burn and fire hazard to consumers.
Incidents/Injuries: Mintek has received 10 reports of incidents, including nine cases of the battery pack overheating and/or catching fire and one report of the battery pack overheating and bursting.
Description: The recall involves battery packs used with the Mintek portable DVD players with a 7” (diagonal) screen and model number DVD-1710. “Mintek DVD-1710” is printed on the top and bottom of the unit. The DVD player is silver and grey colored and the battery pack is silver with a nameplate on the bottom that is marked RB-LiP01 or RB-LiP02.
Sold At: Electronic and department stores nationwide, including Best Buy, from September 2002 through January 2005 for between $200 and $300.
Manufactured in: China
Remedy: Consumers should stop using and stop recharging the battery pack immediately and contact Mintek Digital for a free replacement battery. Consumers can continue to use the DVD player, with the AC power adapter and not the battery pack, until they receive a replacement battery pack.
Consumer Contact: Contact Mintek Digital toll-free at (866) 709-9500 anytime or visit the company’s Web site at www.mintekdigital.com. Consumers also can contact the company by mail at Mintek Digital Inc, 4915 E. Hunter Ave., Anaheim, CA 92807
on Jun 09, 2009 | Mintek MDP-1810 Portable DVD Player
How long does it take charge the sunpack 510 batt using the qbc-5
Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
Dec 27, 2014 | Sunpak Cameras
How long do i charge a sunpak nc 510 rechargeable using a QBC-5 CHARGER
Jan 08, 2014 | Sunpak Cameras
My Mintek portable DVD player's battery will not charge. I have rarely used the battery so I can't believe the battery is dead. The AC cord works to power it when plugged in. Why won't it...
After a while even rechargeable batteries loose the ability to hold a charge. This process accelerates when the battery is allowed to lie completely discharged for long periods of time. NiCad batteries especially have this issue. If you left the battery sitting for long periods without occasionally charging it, it losses the ability to hold a charge. It appears you are going to have to either do without the battery or replace the pack. I would take out the old one, it will eventually start to corrode and leak and if its still in your machine it will cause damage. If you get a new battery pack make sure you charge it fully and then depleat it completely before recharging it. hope this helps.
Jul 26, 2011 | Mintek MDP-1880 8.5 in. Portable DVD...
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
No problem just bought a mpd-1760 from someone its brand new never even been used ,but no instructions/need to know how long to charge battery for first time or at all //charging time for battery to watch...
To charge the battery back you want to
  1. Turn the power off the DVD player first as the battery pack will not charge with the power on.
  2. Attach the battery pack to the player.
  3. Connect the AC power adapter and the power cord to the player.
  4. Charging will now start and the Power/Charge indicator should now be orange.
  5. Do not unhook either cord until the Power/Charge turns off.
  6. Time of charging is approximately 4 1/2 hours.
  7. The battery pack will more than likely get warm while charging. This is normal. Keep it as much in the open as you can for the best ventilation possible.
  8. You will get a low power indicator on the screen when the battery has a low charge.
As for playback time you will get about 2 1/3 hours of actual playback and about 4 hours of standby with the DVD player actually on.
Regards, Tony
Apr 12, 2011 | Mintek Televison & Video
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
I am charging my new Flip Ultra HD battery pak for the first time. The charging light is flashing, non-stop. I thought the light was supposed to NOT flash while charging. Also, should the camera...
1) remove the battery pack from the camcorder
2) connect the camcorder to a powered USB port on your computer
3) when the "Connected" indicator comes on, insert the battery pack into the camcorder
4) safe eject your camcorder from your computer
5) reconnect your camcorder to your computer
6) the battery pack should now begin to charge within the camcorder
Jul 22, 2009 | Pure Digital Flip Video Ultra Camcorder
Mintek MDP-1760 Portable DVD Player Logo
162 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
