Question about Honeywell Heating & Cooling
Reset service timer on honeywell ST6100s
The service interval has come on our boiler. I need to reset the service timer to get hot water.on a honeywell ST6100s
5 Suggested Answers
  • 148 Answers
SOURCE: Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
Posted on May 10, 2009
billyvangogh
  • 108 Answers
SOURCE: need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Posted on Oct 26, 2009
  • 36 Answers
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Posted on Jan 31, 2010
  • 3248 Answers
SOURCE: Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Posted on Feb 18, 2010
I have recently brought my hous3 and have a Honeywell ST9400S. It says it needs a code as a service is due but this was done the week before I moved in. How do I find the code to override this.
Here's a link to the manual. You'll probably need it for future and current issues.
https://www.google.com/search?q=Honeywell+ST9400S+manual&ie=utf-8&oe=utf-8&client=firefox-b-1-ab
Resetting the Service Timer Function
If the Service Timer function is enabled you will be required to reset it after the boiler service has been carried out.
The process for resetting the Service Timer is as follows:
a. Enter Installer Modes (as described on page 3 see manual) and navigate to SET SERVICE mode. In response to the query 'SET SERVICE OK ?' press the button to enter SET SERVICE mode.
b. If you no longer require the Service Timer, disable it by setting parameter AL to 0 and confirm with the button.
c. If you still require the Service Timer, set the number of days until the next service is due using parameter d and confirm with the button.
d. Whilst in SET SERVICE mode, use the opportunity to change any other service parameters if required.
e. Exit by moving the slider to the next position and back again to RUN
My suggestion is to download the manual and print a hard copy to have when you begin the reset process.
I know i'd need it! :)
Cheers
Feb 14, 2018 | Honeywell Heating & Cooling
My honeywell timer for the back boiler heating is blank
need to contact the people who worked on it yesterday to come back and look at it again because it sounds like you have no power to now.
Jan 29, 2010 | Honeywell CT3600 7 Day Electronic...
Ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Boiler is a baxi control for heating is honeywell.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
May 08, 2009 | Honeywell Programmable Thermostat Heater
I have a honeywell st6100s, i have just had it serviced, but it still flashes up service due and reads off and the timer can not be set
Normal 0 This unit can be reset, just a little complicated thats all.
Firstly, move slider to 'set program'. Then, on the left of the unit are two buttons, 'override' & 'extra hour'. Press and hold both together 'till 'inst' shows on the panel ( about 5 seconds ).
Then ( lots of fingers required! ) press and hold the two buttons mentioned above, along with '-' '+' & 'next on/off ( total of five buttons! ) until the user menu flashes up.
Now scroll to AL, which is probably showing a value of '1', this wants to be changed to '0' to turn off the 'service due' warning. To save this value, press and hold the first two buttons once more and then simply move slider back to 'run program'.
Job Done!!!
I hope this helps. It should certainly remove the annoyance of having to phone your housing association and then sit around waiting for them to show!!
Nov 18, 2008 | Honeywell Heating & Cooling
Hot water boiler
contact honeywell with right model no. and they should be able to help or try online on honeywell website.
Dec 12, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
213 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
