Question about Dryers
My Kenmore Series 700 dryer runs but has no heat, what is the problem
    Problem Solver:
  • 9 Answers
Could be thermal limiter fuse, there are usually two in the back of the unit. It can be blown and the drum will turn but the unit won't heat.
Posted on May 02, 2010
Kenmore 700 series dryer problems
This could be a few things. The first thing to check is your dryers vent, make sure its not clogged and check were it exits the house because sometimes nest are made in them. A clogged vent will prevent proper drying because the moisture can not escape and/or the heating element turns off due to overheating.
If the vent is clear, with dryer empty open the door and hold down the door switch (button that tells dryer door is closed) and turn on dryer, as its running watch the back area of drum were the vent with little holes is, within a few seconds you should start to see an orange glow in that area. If the orange glow starts then disappears within a few seconds it means your vent is clogged, if there is no orange glow at all then you have either a bad heating coil or bad high limit switches. I believe youtube has great how to videos on how to replace them, its not that hard if you have basic repair skills. Hope this helps you and your able to get it drying agian
Dec 23, 2013 | Dryers
I have a Electric Kenmore Dryer 70 series. No heat and timer doesnt work.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 28, 2011 | Kenmore 700 6972 Dryer
I have a 2007 kenmore 700 series gas dryer. 77751. it has quit drying clothes. if i turn it on, let it run for a few seconds, then open it and stick my hand inside, i can feel some heat. if i then close it...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Kenmore Dryers
Kenmore 700 series gas dryer, runs but does not get hot. Needing a troubleshooting check list to find the problem.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Kenmore Dryers
Have a Kenmore Haevy Duty 70 Series Soft Heat model #96576200, I set the time push the on button dryer comes on to start drying but shuts off within 30 seconds. Any suggestions would be appreciated
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
a
Sep 27, 2010 | Kenmore 700 6972 Dryer
The dryer won't light 70 series Kenmore (gas)
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 08, 2010 | Kenmore 700 6972 Dryer
Our Kenmore Series 700 Electric Dryer works but won't heat up. What can be wrong?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Kenmore 62602 Electric Dryer
Gas dryer won't heat up. i need the wirind diagram to a 700 series kenmore gas dryer
Here is a tip that will help you with your problem..
believe it or not it is not an electrical problem, but an ignitor problem...
heatman101
Mar 27, 2010 | Kenmore 73952 Gas Dryer
Dryers Logo
142 people viewed this question
Top Dryers Experts
