Question about Microsoft Windows XP Home Edition
On ventrilo I get an error message thst says unable to load outbound codec gsm6.10
Unable to play my MP3 files on Windows Media Player. Getting error message "The audio codec identified by the format tag 55 is required to play this file." Pls advise how to fix this. Thanks...
Dear rimpexenter
Download and install this codec pack
http://www.free-codecs.com/k_lite_mega_codec_pack_download.htm
And try to play it on media player classic(321 player).
Thanks for using FIXYA
Mar 15, 2011 | Computers & Internet
Error ID=0xC00D119A, Condition ID = 0x00000000 Web Help
This is a noted common error going back to the early 2004....
This error message (Error ID = 0xC00D119A) means that Windows Media Player was unable to download a Codec it needed to play the file you were trying to listen to.
Beacuse windows media shares your internet settings, I'd start by going to IE's tools->internet options menu
Check the Security tab for internet and go to 'custom level'. See if 'Allow file downloads' is checked - if not, check it, OK out, restart IE and windows media and try the codec download again.
If it works you should be able to set your IE security back to 'refuse file downloads' until you need it again.
good luck ....
Sep 28, 2010 | Microsoft Windows XP Professional
Mtv converter is not accepting any video files.Load video failed message is coming.give me a solution.
you can ask for technical support from video converter company. or u can try this one.
http://www.flip-converter.com/
Oct 18, 2009 | Transcend T.sonic 610 MP3 Player
Ventrilo static weird occurance
First, make sure your mike/headphones are plugged in all the way to the correct jack port.
Then, re-download and install vent.
Also, go to "setup" in vent, then make sure the inbound and outbound are either set higher or lower than the default.
Hope these help, and please rate ^_^
Mar 07, 2009 | Dynex Stereo Headset with Noise-Canceling...
Ventrilo 3 stuck at synchronizing, cant connect.
This problem normally appears when using routers and having NAT enabled
To Fix this do the following:
Enable port forwarding to port 3866 UDP and TCP
Feb 22, 2009 | 3d Rose Londons Times Funny Music Cartoons...
Explorer.exe error message
I think you have some problem with codec..Try to download & install codec..
Nov 02, 2008 | Computers & Internet
Error message
Get a decent codec pack.. search for K-lite codec pack or cccp codec pack, install.
Oct 25, 2007 | Compaq Presario Notebook
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
