Question about LG UX3300 Cellular Phone
How do i locate my ux300 sim card - LG UX3300 Cellular Phone
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Where is the sim card located on my motorola flip phone Model V276?
Hello Lynette, the Sim Card is locate in the back of the phone. You will have to open it and take out the battery and you will see the Sim Card trade.
Jul 28, 2014 | Motorola Cell Phones
Location of sim card
Sim card is normally under battery can't be clearer u don't say which model it is sorry
Oct 26, 2012 | Nokia 1006
I need to replace the sim card
In almost every cellphone the Sim Card is located under the battery. Open the back of your phone where the battery is located and remove the battery. You should see the Sim Card that you want to replace. Most Sim Cards slide under a small holder. Gently slide the Sim Card out. Make sure that you are aware of how the old Sim Card is positioned so that you can simply slide the new Sim Card in exactly the same way as the old Sim Card came out. Replace the battery and close the back cover and you are finished.
Oct 05, 2012 | Motorola Mobility V950 Cell Phone
How do I download photos from my LG UX300 cellular phone to my computer?
If your photos are stored o a SD memory card then trmove the memeory card from your cell phone and insert it into an USB memory card reader. Plug the USB card reader into the USB port of a working computer. The computer will see the memory card as an external storage device. You can open the pholder on the memory card that contains the photos and copy the photos to your computer.
Feb 26, 2012 | LG Cell Phones
When i switch on my mobile..it said "sim card rejected".....wht can i do now for solvng ths prob
If the SIM card was working before, then remove the SIM card from the cell phone and clean the contacts on the SIM card and the contacts on the phone where the SIM card is located with alcohol.
Then replace the SIM card in the cell phone.
The cell phone should work again.
Dec 04, 2010 | Nokia 1616 Cell Phone
How to change the simcard of my apple 3g iphone?
The SIM card in the iPhone is removable, but it's hidden. To remove the SIM card, you need a paper clip.
We are checking to see if this voids your iPhone warranty. If you are concerned that it might, please don't perform this task.
The iPhone's SIM card is located behind this door.
1. Locate the SIM Card Slot
The slot is located at the top of the iPhone, between the headphone jack and the power button.
The paper clip is a valuable tech tool.
2. Open the Slot
Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up.
3. Remove the SIM Card
The SIM card is in a cradle. You can pop the card out of the cradle.
To replace the SIM card, put the card back in the cradle. The cradle and card are notched in a way that forces you to replace the card on the proper side. Then just slide the card back into the iPhone.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Apple iPhone 3G
SIM card location
The Chocolate phones do not have sim cards.
Dec 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Motokrzr sim card
Yes, you can use the same SIM card on a Blackberry and Motokrzr
To access the SIM Card on Motokrzr, slide open the back cover and remove the battery. The SIM card is located towards the top side of the phone
Dec 10, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell phone sim card
All mobiles have a sim card and are normally located under the battery.
Take the back of your phone, remove the battery and it should be there. Sim cards are normally a small oblong piece of plastic with a corner cut off. The flip side of one will have a metal strip, which is your sim memory. Don't damamge this side of the sim otherwise your card will be useless.
Hope this helps?
Dec 29, 2007 | LG VX8300 Cellular Phone
LG UX3300 Cellular Phone Logo
230 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
