Question about Craftsman Garden
I am replacing the pull rope on a Craftsman bushwacker model # 358795800. The clutch and the washer needs to be removed in order remove the plastic fan housing. I am using the diagram on searspartsdirect.com. How do I remove the clutch? There are no screws.
  • 1 more comment
  • tracy_osborn May 01, 2010
    Thank you for the manual link. I already have the manual and it does not describe how to replace the rope. I also chatted with Searsparts.com and they could not help.
    Looking at the clutch it appears a screw drive or another tool should go beneath and stop the clutch from turning then, maybe it pulls off. I do not want to break something while I am replacing the rope. Any advice, it would be appreciated.
    I do not see a bolt. If you see the diagram at www.searspartsdirect.com it shows figure 49, the clutch. Figure 48 is the also called a clutch, however, that is where the rope wraps around. I can not remove the figure 49. What is a 'puller'? Do I need a special tool to remove the clutch?
  • tracy_osborn May 02, 2010
    I figured out by the help of U Tube that a screw is located at the bottom of the clutch. That screw is so tight that it broke my screwdrive. What can I do to loosen the screw?
  • 370 Answers
Ok first things first remove the screws that holds the shaft on to the engine these are in the handle of your model, then remove the handle from the engine this will allow you to see the clutch assembly, this clutch is a centrifical clutch so there will be no pressure on it untill it hits a specific RPM thus pulling the clutch out and engagding the shaft, so you have the clutch exposed it till spin off, rmember that it till be left hand threded. (threds backwards), here is the trick take a punch and hammer and use it to spind the clutch clockwise. This will expose your rewind for repair.
Posted on May 02, 2010
  • 11,896 Answers
Remove the bolt and use a puller and it will come off
Posted on May 01, 2010
  • Nate Stansfield
    Nate Stansfield May 01, 2010
    The puller is the special tool that pulls clutches and pulleys.
    Since there is no not on this one, you can try and put a socket wrench in the square opening, hold the clutch still and turn to see if it comes loose. If you can turn this kind, then you will need a puller to remove it.
  • Nate Stansfield
    Nate Stansfield May 02, 2010
    Heat it up with a torch for a bit, then use a craftsman brand screwdriver. If this has a socket type screw where you can use scewdriver or socket wrench, then I would use the socket wrench. Heat does help to remove, so does a can of "knock it loose" It's like wd-40 but stronger
    Genius:
  • 1,354 Answers
How to replace the pull string on my Cub Cadet ST2020 weed eater.
Very fun job Not. Very involved and time consuming.
First your should be about 3 long some unit uses slight longer ropes and it is probably a number 3-1/2 rope.
  1. Need you to separate the upper drive assembly from the engine assembly. You may to disconnect the throttle cable and the ignition kill wiring.
  2. Remove the clutch cover.
  3. Disconnect and remove the spark plug.
  4. Install a piston stop in place of the spark plug.
  5. Remove the clutch drum. Has small screw in center; usually has a Trox head on it.
  6. Remove the clutch assembly. Usually has left handed threads so turn it clockwise.
  7. Once the clutch is removed then you need remove the starter cover assembly and the air cleaner cover assembly.
  8. Once the starter cover assembly is off remove the pull rope pulley and check for damage.
  9. Depending the pulley design you can now install a new rope first or you need to re install the pulley.
  10. Tighten the pulley fully by turning the direction as you would pull it until it stops and back off one turn.
  11. If the pull rope hasn't already been install install it now. Otherwise make you have the pull handle on the rope and release the pulley tension slowly until the rope is tight.
  12. Now re-assemble everything in reverse order.
Feb 12, 2015 | Garden
How do i replace the start rope on my craftsman bushwacker model number 358.795800?
Your starter rope may not be the only problem you have. Could it be that you had a hard time starting the unit? If so it could be crankcase bearings are worn and is causing unit to vibrate, which in turn damaged the starter.
Oct 09, 2013 | Craftsman Garden
How do I remove the hassel free head of my craftsman trimmer model 358.791170
I can get you part way there. Remove the spark plug and shove some clean rope in the cylinder to prevent the engine rotating. Take the front housing off to access the clutch assembly, pull off the black plastic cover from the shaft end, and use a torx wrench to loosen the screw in the end of the shaft. After it's loose, the clutch drum will come right off. Unfortunately, I am stuck now trying to get the rest of the clutch assembly off without damaging it.
Sep 17, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
How hard is it to replace the starter pull cord on a Ryobi 725r gas weed trimmer?
With the proper tools, it is a moderate level project for the DIY mechanic. You will need T15, T20 and T25 torx drivers. 5/8" spark plug socket, Large lip-joint pliers, phillips head screwdriver, 40" of #3.5 rope and about an hour. Start by removing the shaft from the engine. Take pictures as you go. This will make reassenbly easier. The black housing removes next. This will expose the clutch drum. There is a T15 or T20 screw in the middle of the drum. It removes counter-clockwise. Next is the clutch itself. Remove the sparkplug and lower the piston to the bottom of the cylinder. Push as much of the old rop down into the cylinder as you can, then raise the piston up to "lock the cylinder. Now you can use the pliers to turn the clutch counter-clockwise to remove. Don't lose the little washer that is ontop of the clutch, or the thick washer that is under the clutch. Be careful with the clutch, you don't want to damage or misposition the springs on it. They are pretty difficult to reinstall. Next, remove the airbox cover and disconnect the throttle cable. Remove the remaining screws form the tan plastic housing and take it off. Inside this housing is the recoil pulley. Remove the pulley, install the new rope. Wind the rope on the pulley and pass the loose end thru the eye and tie on the handle. To tension the spring, install the pulley and wind more of the rope around the pulley. Reassmble in reverse order. Make sure to get the clutch tight. Failure to tighten the clutch properly can cause major damage.
Aug 25, 2010 | Ryobi Garden
Need to replace pull rope
You will need to lock down the cylinder to remove the clutch. This is not an easy repair. Remove the spark plug and lower the piston. Take a piece of small rope (the broken one works fine) and fill the cylinder with the rope. Raise the piston to "lock the cylinder. The clutch drum can now be removed by inserting a T15 or T20 torx into the center and turn the screw counter-clockwise. Then take a pair of large slip-joint pliers and turn the clutch assembly counter-clockwise to remove. Make note of what order all the little washers come off. Also, make sure to remove the clutch as an assembly...it is very difficult to put back together. When reinstalling the clutch, it is VERY important to get it tight. Failure to get the clutch tight will result in major engine damage.
Make sure you replace the rope with 40" of #3.5 braided rope. Melt the ends of the rope so it doesn't fray and use a figure 8 knot to secure.
Aug 24, 2010 | Troy Garden
How do you remove the clutch drum assembly for model #316.791890
Your clutch drum is held on with a Torx head screw which is screwed into the end of the crankshaft. To lock the engine up so crank won't turn, remove the spark plug, rotate the engine so the piston is down and put some clean pull rope or otherwise soft material in cylinder. ...make sure it is something that won't hang up in the ports on the sides. Then when you rotate the crank, it will compress the rope or soft material, locking up the engine to facilitate removal of the Torx screw, The screw will come loose but will probably not come all the way out...that's just the way they made it.
Jul 08, 2010 | Craftsman Convertible 25cc. Gas Line...
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Jun 06, 2010 | Craftsman 22" Gas Hedge Trimmer
Start Pull cord replacement on John Deere s1400
Take the 4 bolts/screws loose that hold the shaft onto the weed-eater body, You will see the clutch drum, you need a long T20 TORX driver to loosen the screw in the center of the drum shaft. The screw probably won't come all the way out, so just pull the drum off as you loosen it.
Next you will see 3 flat clutch discs.
You may need to remove the spark plug and stuff some starter rope in the combustion chamber to keep the shaft from turning.
Unscrew these one at a time with a pair of large slip joint pliers. Be careful not to bend them and note which way they face. They unscrew clockwise I believe.
Once you have these out of the way, continue taking apart the plastic housing to gain access to the starter rope assembly. There is a spring under the rope reel, so remove the screw holding the reel in place and carefully remove the rope reel and spring.
Replace the rope, put the reel back in place and make sure the sping egages the little tab. Then wind it a few turns until there is moderate tension on the spring.
Feed the rope through the body and tie it to the T-handle. Replace the hold down screw that keeps the rope reel in place.
Test the pull tension before reassembly. It should retract the rope fully without too much tension and should not be loose. Lubricate the rope reel where it rubs against the housing with some light grade oil or lithium grease.
If everything functions, put it back together in reverse order.
Remove the rope from the combustion chamber and make sure there is no debris in it. Install the spark plug. You should be ready to go.
Aug 21, 2009 | Garden
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Garden Logo
170 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
