Question about Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher
I have an old free standing Maytag portable dishwasher, model number WC504. I just need to know what the differences in the drying options are. What is the difference between Power Dry, Temp Boost, and Energy Saver? Also, If drying plastic or Tupperware in the dishwasher, Which setting should be used?
    President:
  • 949 Answers
Power Dry uses a little more electricity when drying but does a good job.
Temp Boost will raise the wash temperature to clean better, this uses very little extra energy and works well, it may add a little time to the cycle
Energy saver will not dry the dishes or boost the water as hot as needed to sanitize. It will save about 2 cents per load.
If you need plastics to dry always put them in the top rack and use the power dry. Use rinse aid to help with drying.
Posted on May 02, 2010
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
I recently purchased a portable Maytag dishwasher model # MDC4650AWW. So far so good but I would like to have a user/owner manual if possible. I am not seeing this model listed and wondered if it has...
You can download the manual from the manufacturer's web site at
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%206-920109.pdf
Nov 16, 2010 | Maytag 24 in. MDC4000 Free-standing...
Need 2 casters
Is the model number FMP330RGB as listed at the very top? That number does not cross.
There are the parts listed as wheels / caster for Frigidaire:
http://www.repairclinic.com/Frigidaire-Dishwasher-Parts?s=b2a9c252
If you need more assistance just respond here with the complete make and model number and we will help you.
Thanks for using FixYa.
Kelly
May 12, 2010 | Frigidaire FMP330RGB Free-Standing...
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Adapter for Kenmore 17669 portable dishwasher
Hi, Please get me the model # from the label inside the door openong and I will look this up for you.
Vic
May 28, 2009 | Kenmore 24 in. 17669 Free-standing...
Top arm came off of AM 14 model
www.hobartservice.com, select parts on the left and either select model from the lists or enter your ML number. You will get exploded view drawings with links to part numbers when you click the item numbers.
Apr 27, 2009 | Hobart AM14-253 Free-standing Dishwasher
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Feb 05, 2009 | Maytag 24 in. PDC3600A Built-in Dishwasher
Portable dishwasher
The first thing you might want to do is check the water pressure in the house. Ideal water pressure should be from 55psi to 75psi max. I have seen homes that had pressure around 125 psi which will cause pressure leaks in water heaters, softners, washer valves, r/o systems. Check to see that all, if any inlet screens are clear and free from any grit and sand. It's possible that your inlet water valve (wd10m0010) has become restricted. Other than that, the complete uncoupler hose assy. part number is wd24m0030. These parts are for the dishwasher model ending in gsc3400j00bb. They are the same for model number ending in 00ww. Good luck.
May 07, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher Logo
132 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
