Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Runs only when I pour gas directly into carb
Has sat for two years.
Now runs only when I pour gas directly into carb
    President:
  • 512 Answers
Plugged gas lines or they are brittle and cracked not allowing gas to be pulled through. Also carb bowl could be clogged.
Posted on May 03, 2010
Not getting gass but fuel pump works & gas is clean, also it has sat inside for 12 years
Well if the pump works then follow the pump fuel lines to the engine,you will find the fuel filter then replace it and will also see petrol if any in it ,if not pump isent working ,if dirty replace it and blow air back from carby to filter to clean out pipe
,turn on ign fuel should come to filter and then with new filter in turn on fuel and see if any comes to carby if ok it should start and run.
Have a goodday,
Mar 19, 2015 | 1986 Toyota Hilux 2200
Mower will only start with gas poured directly into the cylinder
You need to rebuild the carb. The kits are cheap. Less than $10 for most. If that does not work possible carb replacement needed. Sometimes these carbs get clogged an cant be opened because orifice are to clogged. Carbs are not expensive. For $20- $25 it can be fixed.
Mar 22, 2014 | Mtd Garden
1997 polaris trail blazer 250 fuel pouring out of exhaust
Your needle and seat is stuck open.Youll have to open up the carb.
I have changed lots of these. I worked for polaris for nine years.
Jun 06, 2012 | Polaris ATV
Lawnmower sat up for a season would not crank replaced sparkplugs air filter fuel filter hose fuel pump is pumping gas to carburator but still will not start unless you pour some gas into the carburator or...
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
Aug 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Mar 16, 2009 | Coleman Powermate Powermate 5000W...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
200 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
