Question about Sewing Machines
I have a Kenmore 385.1950280 that has been in storage for
I have a 385.1950280 that has been in storage for years. It will fill a bobbin but when trying to run get a error code.When trying to run in sew mode it will run maybe one turn then error code and refuse to run anymore untill turned off then back on. If you leave the clutch connected and the bobbin pin to the right it will run then stop when using the pedal. But will run again with another push of the pedal without a error code.
    Genius:
  • 1,116 Answers
When a sewing machine has been in storage for an extended period of time, it will need to go into the shop for service.
There could be several things that need attention and one possibility may be replacement of a circuit board.
Posted on May 01, 2010
Kenmore sensor 70 the bobbin won't fill, when i pull center knob to fill bobbin. the spindle won't turn. to spin the bobbin
Re: Bobbin Winder Won't Turn:
This should not be too difficult to fix if you open the top of the machineto see what is/is not going on inside. Most likely the rubber O-ring, or rubber "Tire", as some call it, is either out of adjustment, dried or worn too much to work. If adjustment is not the problem, than replace it with a new O-Ring of the proper size. With this done, it still will need adjustment. Hope this Helps.
Sincerely, --Amender (2018 FEB 19).
Feb 16, 2018 | Kenmore Sewing Machines
How to fill a bobbin on a Rivera 1681?
fill-bobbin-rivera-1681-d05l30nuhtdrvd3uj4vejdej-1-0.jpg These videos may help. Not the same as your machine, but the way older sewing machines wind bobbins are pretty similar.
1 How to wind bobbin on the Brother XL2600i sewing machine
Loading thread on the bobbin old Kenmore sewing machine
Jan 04, 2016 | Sewing Machines
Motor is spinning- needle not going up and down.
Check that the inner part of the flywheel is tightened up. This has to be loosened when winding a bobbin for underthread. Easy to forget to re-tighten it for sewing.
Apr 14, 2010 | Kenmore Sewing Machines
Can't put thread on bobbin
I cannot tell what your problem is. The winder isn't working? The bobbin won't hold the thread so it will fill?
There are threading guides at the sewusa website that may be helpful as they include written instructions along with graphics.
Mar 13, 2010 | Kenmore Sewing Machines
Bobbin Winding
Your flywheel is lacking a drop of oil and possibly some cleaning.
What kind of machine is it?
Sep 14, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Bobbin Winder not working
sounds like the bobbin is not all the way down on the peg.
May 15, 2009 | Kenmore 11101 Mechanical Sewing Machine
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
