Question about Mtd 22" Yard Machine Push Mower
Oil coming from line from engine feeding into air
Oil spitting from line from engine feeding into air filter chamber on yard man push mower.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 46 Answers
More than likely your air filter is clogged and needs replacing. If that is the situation the carb needs air and is pulling suction on the crankcase breather tube siphoning up oil instead of just burning the vapors. If it was a busted ring the oil would be coming out the exhaust and burning blue smoke.
Posted on Jun 09, 2010
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Engine only runs with choke on. Blue smoke comes out and engine runs rough or not at all
sounds like you have a bad Ring on the Piston or a blown head possibly. Blue smoke means Oil is getting into the combustion chamber. Full choke means you have to give this 'broken' engine a lot of gas to compensate for it's problem.
Do you change the oil at least once a year? Filthy oil or a lack of oil will kill an engine
Aug 06, 2012 | Yard Man Garden
Won't start...turns over...took. Air filter off and gas and oil mixture shoots up into their once it starts
sounds like the needle valve in the carb is not seating and the fuel is draining into the oil
May 14, 2012 | Yard Man Garden
Yard works mower wont start
check the fuel filter if not you need to clean your carburator
May 02, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
My mower is spitting oil all over the driveway and smoking. The pull cord will not pull
It is important not to over fill the sump with oil, only fill to the max mark on the dip stick, if you have tipped the mower up it may have pushed oil up the engine breather and into the air filter box, if the paper filter is now soaked in oil you will need to replace the filter.
Apr 28, 2012 | Garden
I recently changed the blade on my 22" Yard Machine push mower. It is a 22" blade. A bunch of oil spilled out of it when i turned it upside down and it was replaced. Now the chord on my mower is...
it will be o.k. theres just some oil in the combustion chamber making it hard to compress the air,when it starts there will be a lot of white smoke,thats just the oil in the cylinder burning away/off then you will be o.k.just make sure its close to the full mark before you start it and after you shut it off and it has set a while to drain back to the oil pan
Aug 04, 2010 | Mtd 22" Yard Machine Push Mower
Blown engine
A dirty air filter will reduce the power produced by the engine, and eventually may make an engine stall, but it does not cause it to "burn oil". You have options, so just work your way through them: 1) manager/owner of the repair shop - will they stand behind their repair work? 2) the warranty and protection plan from Lowes. Go in with the right attitude - don't direct anger at the person you're talking to, just describe your issue and ask them what they would do in your situation? If you get turned down, politely ask to escalate the issue to their supervisor, etc. Good luck to you.
Jul 30, 2010 | Husqvarna 23HP VTwin Hydrostatic 48" Cut...
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Where are the air and oil filters located
I don't think you have an oil filter on your push mower. You can go to www.buymtdonline.com and look under illustrated parts look up then enter your model number of your LAWN MOWER not your motor and it will give you a parts listing for mower and look under the sub categories for the engine and it will show you where the air filter is located and oil filter (IF ONE). Look at the little number by the air filter then scroll down to that number below the diagram and you will get the part number for the filter.
Hope this helps
roundo4
Aug 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd 22" Yard Machine Push Mower Logo
464 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
