Question about Craftsman Garden
When I engage the deck the tractor shuts off - Craftsman Garden
  • 454 Answers
There is a safety switch in the seat, if that is defective or disconnected, those are the symptoms.
Posted on May 01, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Engine shuts down when cutting deck engaged
This is probably due to a misadjusted or faulty safety switch on the rider's seat. There is a deadman switch there that will shut down the mower if the rider gets off the seat with the blades engaged.
Mar 06, 2015 | Garden
Sears 21 h.p. lawn tractor
Sounds like a safety interlock. Was there any electrical wires going to the deck, to the engage switch, the up down lever? There is a neutral switch that is closing or opening and the circuit is shutting down the motor.
Feb 08, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Cub Cadet 2135 mower deck issue: Started OCCASIONALLY shutting off on turns and down slopes. Turned the switch off then on and it worked until another seemingly random time as above. Now, deck...
repair the seat first remove seat and reinforce metal use metal plate on top and washers on bottom or reverse make sure seat is secure so that u do not loose the ground contact on safety switch their is also a safety switch on shifter lever and brake pedal check them for rust and a tight contact
Nov 02, 2013 | Garden
Another name for a coil
not sure what your asking does the tractor shut off or does the blade engage shut off or disengage?
Jul 28, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My tractor keeps shutting off when i engage the mower blades
It would depend on what model, but could either be a deck drive problem or safety switch. With tractor off, I'd check the blades for free movement with no binding. If this is ok, then I would suspect the seat switch. The mower will not run with the deck engaged, and no operator present. It could be the seat switch is not making, so when you engage the deck it kills the motor. Test switch
Aug 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My Cub Cadet i1042 tractor shuts off when the blade is engaged. This happened after I ran over a ***** and/or stump. Every time I try to engage the blade the engine shuts off.
Check for bent blade against deck housing.Possible you bent something on mowing deck,check all spindles and pulleys.You could have something hung on blade and making contact with deck. Rarely will the motor be hurt from hitting object on rider.
Apr 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
Jul 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
