Question about Sears Lawn Mower Ignition Switch Replaces AYPROPERSEARS 158913
Just stopped, put in gas, turn key...NOTHING
Sears Lawn tractor about 9 years old
Found my 20amp fuse in the bottom of an electrical block under hood on the ignition key side it was not visible till I took block loose from mounting point. Not in any manual or web-site. This is an easy way for a shop to charge for and easy fix.
Posted on Oct 07, 2012
    Guru:
  • 63 Answers
If it has a Briggs and Stratton motor open the hood and look all along the wire harnesses. There might be an automotive type plug in 20 amp fuse that has blown. If it did blow there is a reason. First look for a dead short somewhere. Mine was a loose wiring terminal at the headlight. Replace fuse and try to start.
Posted on May 12, 2010
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Engine will not turn over
I would check the key switch, the solenoid and the cables, your problem is most likely in one of those three. When you say you have plenty of voltage, what are you checking it with and how old is the battery? Batteries for lawn mowers only last about 1-2 years. And if they are a smaller cranking amp battery on a larger hp then they will not last as long.
Apr 15, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Where can I find the model number on my Sears riding lawn mower? It is about 6 or so years old.
Sears puts the model numbers under the seat on most machines since 1990. They are in the format
xxx.xxxxxx
example 538.678567
Good luck
Mar 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
My craftsman lawn tractor seemed to overheat and struggle with hesitation. I replaced the spark plugs, cleaned the filter and added oil, however, it still seeems a little sluggish with hesitation. Do you...
Check the oil, if it is a milky color then it has water in it and will cause it to over heat. Also smell it for gas that will also cause it to over heat. Has any other work been done recently?
Aug 19, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Sears Riding Mower stops running when the blade is engaged
check the deadman sensor under or in the seat. if it don't "see" you on the seat then the mower will shut down. good luck and hope this helps
Jul 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sears Lawn Mower Ignition Switch Replaces AYPROPERSEARS 158913 Logo
164 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Superior Maintenance
Are you a Sears Garden Expert? Answer questions, earn points and help others
