Question about Sony CDX-GT11W Car CD Player
After a battery malfunction, my CDX-GT11W unit is totally dead... The fuse seems to be fine & I trying to see if my head unit could be dead or if another issue could exist.
  • trood May 02, 2010
    Thanks - the fuse in the back is fine, and the fuse box (all six glass fuses) appear fine. What's "fuse to the constant"?
    Scholar:
  • 84 Answers
Have you check the fuse to the constant and the fuse for the accessory (usually separately fused)... you can also check the back of the radio, on that model i believe there is a fuse built in under/behind the harness... Hope this helps!
Posted on May 01, 2010
  • uno_1 May 02, 2010
    What type of car do you have? Basically, the radio has 2 power sources going into it, the "constant" (+) "the yellow wire" which stays on all the time to maintain memory (presets, time, etc.) and the accessory (+) "the red wire" which tells the radio to turn on. Then there is the ground (-) (not fused). usually the constant fuse is under the hood and the accessory fuse is in the cab.
I need operator's manual / instructions for Sony CDX-GT11W
The operating instructions and installation guide for the CDW-GT11W are available from the manufacturer's support site: https://esupport.sony.com/US/p/model-home.pl?mdl=CDXGT11W&template_id=1®ion_id=1&tab=manuals#/manualsTab . Click on the Manuals, Specs & Warranty tab. I needed to refresh the next page to download the manual (click on the circle with the arrow going clockwise). The direct link to the manual is currently https://docs.sony.com/release//CDXGT11W.pdf .
I hope this helps.
Jan 09, 2017 | Sony Car Audio & Video
I need a wiring diagram for the Sony explod CDX-GT11W cd player so I can hook it up to my car
You can download the complete instruction manual in PDF format from Sony CDX-GT11W support website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Jul 01, 2010 | Sony CDX-GT11W Car CD Player
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
My CDX-GT11W punked out, am replacing it w/ an
OK, click Sony Support to download installation guide of CDX-GT11W player that has connection info.
Hope this will help you.
Nov 05, 2009 | Sony CDX-GT11W Car CD Player
Had to have my battery jumped and since then I do not have power to my sony cdx gt210
pull the unit out of the dash if applicable and inspect the rear of the head unit(deck) there should be a mini fuse in the back of the unit or inline with your power supply to the deck sounds like you just blew a fuse
May 08, 2009 | Sony CDX-GT210 CD Player
Sharp ar 122 ccd trouble how to repaire
Sharp AR-122 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 23, 2009 | Sharp Office Equipment & Supplies
Paper tray will not go up or down. Cannot get it to move.
Sharp AR-650 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 19, 2009 | Sharp AR-650 Copier
CAN'T SET CLOCK ON CAR STERO
turn the unit off and press and hold the selection knob until the menu pops up
Jan 23, 2009 | iLO XM-MP3-CD Car Stereo
Sony CDX M730 won't operate manually. Remote operates unit fine.
if it has a fold down face the ribbon cable that sends power to the led facesheild may be broken or just malfunctioning
Jan 02, 2009 | Sony CDX-M730 CD Player
Sony CDX-GT11W Car CD Player Logo
109 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
