Question about Whirlpool Duet GHW9150P Front Load Washer
Control panel light for control locked is one and nothing responds
  • erock96734 May 01, 2010
    I pressed the pause button for 4 seconds and that did not work. I could not find and end of cycle button
    pause button does not respond
    President:
  • 949 Answers
Press and hold the 'End of Cycle Signal' button for 4 seconds and release. Let me know if that solves the problem
Posted on May 01, 2010
  • Philip May 01, 2010
    If you could send me the complete model number from the tag just inside the door I can pull up the diagram to see which button to push to unlock it.
    thanks
How do i get my kenmore dishwasher to change from light wash to any other cycle, its kenmore ultra 13449k900 model, runs fine on light duty
Well, if you can't change the cycle by pressing another cycle button, yet you CAN press Start or Cancel and it responds, then you probably have a bad control console. If nothing responds, then you may just have the control-lock (or child-lock) feature turned on.
Oct 20, 2014 | Kenmore Dishwashers
Sparform hot tub blower won't turn off
When an appliance will not turn off, no matter what you press on the control panel, you have either a non responding (dead button) topside control panel, or your topside panel did receive the message to turn it off and the circuit board is not responding.
  • If you have some kind of indicator light when you press your Jet/pump button, if the topside panel is operational and does actually receive your request to either turn on or off an appliance, an indicator will appear - either a light or icon.
    • If one does appear when button pressed, then dis-appears when pressed, that means your panel is good - as it is responding to the pressing of the associated button.
      • Bad circuit board
    • If nothing appears when you press the button, no lights or icons - indication of topside receiving your request, then you you have a dead button.
      • Bad Topside Control Panel
May 18, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Control panel failure
Have you tried unplugging and plugging the fridge back in? This may reset the control baoard.
Apr 13, 2014 | Refrigerators
I have power but the lights and pumps do not work when I push the control panel buttons
When you unplug & reconnect the topside control what happens?
If nothing your control is bad, you'll need a new one.
They are typically attached with double sided tape so removal is easy.
Nov 12, 2012 | Pool & Spa
Kenmore ultra wash model 665 has lock on light. Does not respond to no heat dry four seconds.
Press and hold the heated dry button for 5 seconds and see if that will unlock the control panel. If not then try to flip the circuit breaker off for a minute and see if it resets. If nothing resets, then you just need to replace the control board because it's shorted.
Good luck.
Draven at www.ApplianceRepairLesson.com
Mar 04, 2011 | Kenmore Dishwashers
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal De
