Question about Minolta EP4000/5000 CS/PRO Copier
On my Minolta CS Pro 2080, I have the code: C 0500.
Also the door that hold the 8 and half by 14 keep on stop working
  • yazouka May 01, 2010
    My Minolta is a CSPRO 2080 is it the samething, please reply ASAP cause am having problems
    please reply asap cause am having problem and I can't see the small cover and the screew
    President:
  • 2,923 Answers
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Posted on May 02, 2010
    Genius:
  • 1,354 Answers
Open front door close and locate a samll cover on the lft side below panel.one screw open it and you will c 2 botton on a small board one should say trouble reset depress once
good luck
Posted on May 01, 2010
Display error co500. Please help?
Open the front door, with power on. upper left small access cover remove and press trouble reset switch if the code comes back DO NOT RESET means a problem with the fuser (The hot Part) it can catch on fire that will ruin a perfectly good day. Have a tech come out look at it. He need to be old school that is a legacy Minolta machine, Now KonicaMinolta. For parts try this site.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Parts such as fuser lamp, thermistor and thermostat
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 17, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Access code needed
Access to what service mode or admin mode, pin#
Mar 29, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Book Maintenance Copiers Konica Minolta cspro ep300
Exposure lamp the bright light under the big glass is burned out, try reset, by opening front door look to your upper left small access plate remove it this must be done with machine on. press the reset button if the code goes away OK. If not replace the exposure lamp if you can find one a very very legacy Minolta machine!
Nov 27, 2013 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Detaile of Code of Minolta Ep 6001 coper
pleas send me cs pro 6001 code 611 salvation
Feb 12, 2011 | Garden
Minolta cs pro 2080 Has a code 0200 What to look for to fix. Thanks in advance for your help!
Hi !
check for the corona wire if its not broken.....you have a charge problem.
Jun 17, 2009 | Minolta Office Equipment & Supplies
Minolta Di550 error code C-0500
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Minolta EP1030/1030F CS/PRO Copier
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
51 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
