Question about Compaq Evo N610C Notebook
How to return to a large screen... I have pressed keys and then the screen became small, centered...
  • 186 Answers
On top of page in middlex squar dash hit squar orcheck zoom on bottom left should be 125 ok
Posted on May 01, 2010
The display on one of our thermostats became difficult to read all of a sudden, as if the display is going out. When the display is pressed on it is slightly easier to read but not completely. What is the...
Many of these type of thermostats have a power back up. The batteries are two AA and can be replaced. I would expect to see a small rectangle on the screen near the center just left of the large temperature reading. Empty or just one bar is an indication that the batteries are dead.
The batteries are removed from the top.
Nov 24, 2015 | Emerson 1F80-0471 Blue Single Stage...
How to unlock my cell pone BLU T190Q
the three function keys across the top are in cellphoneese referred to by the acronyms lsk csk and rsk. (left center right)
so csk is the large center joypad key.
press it ..try a few times until you see the 'press * to unlock' popup
then pressing * shows you 'keypad unlocked'
then i turned the silly feature off
Dec 13, 2012 | Blu Products Blu Studio 5.3 D510 Unlocked...
My laptop display messed up after power surge
If it is out completely, try hitting your function key and one of the keys across the top, usually has a small screen/large screen icon. The function key to hit is the same color as the F-Key you are pressing, hold function key down, press proper F-key. IF still no picture, take out the battery and unplug. Wait an hour or so and plug in without the battery and try again.
Oct 31, 2012 | Dell Computers & Internet
My E72 font size became huge all on a sudden. I had selected Large font size in the settings, but the size became enormous all on a sudden and so I was forced to change it to SMALL. It is still larger than...
Go to Search... then type Font Magnifier... then just use the scale (press left or right) to change the size of the font you require... then Option to apply. It'll then re-boot itself and the size of the font should be corrected to the one you want.
Mar 08, 2011 | Nokia E72 Smartphone
Hi all, when I press Fn+F3 then screen is sent to external projector, but my notebook's screen became black. What I should do?
The Fn+F3 key toggles between these display settings when you press these keys again.
To the external projector only.
To both the external projector and laptop screen
To the laptop screen only.
Repeat pressing the Fn+F3 keys will cycle through these screen settings again.
Feb 10, 2011 | Lenovo IdeaPad Y530 Laptop
Registration problem konina 7065
timing adjustment, perform the following.
1. Access the 36 mode (power the machine ON while holding down on the 4 and 7 keys.
2. Press [2] Image adjustment.
3. Press [3] Timing adjustment
4. Press [3] Lead edge timing adjustment
5. Press [Copy Screen]
6. Load 11x17 paper into tray 1, make a copy of the pyramid chart, and check the output.
Standard value: 3mm max.
7. If the lead edge original amount is different to the standard value, press the C button while pressing the P button.
8. Enter a value from the numeric keys on the screen, and press (SET) key.
Setting range: 0 (small) to 99 (large)
1 Step = 0.064mm.
9. Repeat steps 5 to 8 until the lead edge original erasure amount becomes the standard value.
10. Press the [PREVIOUS SCREEN) key to return to the Timing Adjustment Menu Screen.
11. Power the machine OFF/ON to exit the 36 mode.
PLEASE NOT THIS IS A LEADEDGE ADJUSTMENT.THE REIGIST ADJUST IS THE SAME STEPS JUST CHOOSE REGISTRATION OPTION ,AND MAKE SURE TO FOLOW PROPER DIRECTION.
Jul 02, 2009 | Sharp AR C250A Color Copier
When i stert my g4 imac,s screen was became blue
You need to reset your pram
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Jul 01, 2009 | Apple iMac All-in-one - 3.06GHz Intel Core...
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
Compaq Evo N610C Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
