Question about Bosch Dishwashers
I have an SKT51 series (silver edition) Bosch free-standing dishwasher. The problem is that a few days ago, when the washing was over and I started emtpying the dishwasger I found in the dishwasher a grey plastic part with the number 5603000027 on it. Obviously, it got loose from somewhere, but I cannot find where it was. The washing quality since then is definitely lower, food remaining on the dishes, which are not properly dried. What could be wrong?
  • elechour May 01, 2010
    What about the loose part?
  • 10,865 Answers
Hello. The best way to find that part is to get your model number. If you are not sure where to look for it go to this link
http://www.searspartsdirect.com/partsdirect/modelCategoryLanding.pd?selectedCategory=mc_dishw
Then use that model number to get a diagram of all of the parts on your machine at this link
http://www.searspartsdirect.com/partsdirect/merchandiser/show.pd?description=Home%20Appliances
Once you spot your part on the diagram you will be able to properly attach it again. Joe
Posted on May 01, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith May 01, 2010
    The loose part could have come loose from the entrance of the dishwasher.
Electric smell bosch dishwasher
Do not use this appliance until you have check if it is one of the bosch dishwashers subject to a recall repair. Use the link below to check
http://www.repairaction.co.uk/bosch
Apr 16, 2013 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Classic Bosch Active & end light are alternately blinking rapidly when turned on. It will not start
Thisjust happened to me. The wash program wasnt set. Check thedial and make sure it is set to a wash program.
Feb 13, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have a Bosch Exxcel washing machine which is great but it bleeps for ever and a day when the wash is finished. How do I silence the beeps without having to get up?
Switch machine on but do not program.
Press and hold PREWASH button.
After a few seconds it begins beeping.
Keep holding PREWASH button in until beep gets quiet
then eventually stops.
Hope this helps - Colin, Billericay Essex
Apr 11, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
I ned help finding a manual for a bosch dishwasher model sgs4012GB
i got the perfect answer. go to thermador.com they can order this for you. bosch, thermador and gaggenau is the same company. if this helps you post a 4 thumbs up post
Feb 21, 2010 | Bosch 24 in. SGS4072 Free-standing...
My Bosch Silver Edition has suddenly stopped
check rinse aid levels a lack of it will effect drying badly.
Jan 19, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Error message E06. Will not start . Bosch Excell dishwasher. Only 6 days old
This error code is the door mechanism or the electronic panel. Mine also had it within days of purchase, got fixed. Seems to have shown up again.
Dec 28, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Where is the float on bosch silver edition?
Hi, This model could well have two systems that will let it fill. One will be on the left hand side as you look at the dishwasher which will require you to remove the side panel. Start with this first as if it is the later version then it will be in the bottom of the dishwasher which will require you to remove the side panels to get to it. The switch in the first method will be a small micro swith and the other will be a large pressure switch located in the bottom. I would think it will be the first method.
Look at it and let me know how you get on.
Feb 27, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher
To find the model number I have to open the door and faintly etched into the metal surround at the top I can see the model number.
Aug 31, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher odor
I have a new Bosch dishwasher which smells up the whole kitchen when the door is opened (between washings). Someone should ban their sales.
May 06, 2007 | Bosch 24 in. SHE43C05UC Stainless Steel...
Dishwashers Logo
50 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
