Question about Microsoft Xbox 360 Console
Xbox 360 open tray error
When i put in my guitar hero 3 disc it will load for a little bit then the dashboard will say open tray. the disc is scratched up just a little bit and i've tried all the toothpaste things and they dont work. all of my other games work and even one of them that works is scratched up more than my guitar hero game. So what should i do?
  • 9 more comments
  • Anonymous May 02, 2008
    I just got the iron man game and it has no scratches on it but it will not work. Niether will Call Of Duty 4 which always works it just keeps sayin Open Tray What do i do??? I NEED help!!! I CANNOT LIVE WITHOUT MY XBOX 360!!!!!!!!!!!
  • cooltime14 Jan 25, 2009
    for all of my games the system loads for a little...... and then says open tray i have no clue wat to do
  • jacinto23 Jan 29, 2009
    my xbox wont read anything CD, DVD, games nothin at all
  • ShijinModan Jan 29, 2009
    I have a Hitachi Model: GDR-312OL ver. 47DJ. I tried gluing the plastic square trick, but it still doesn't work. Anybody know another solution? I know the optical drive isn't burnt out.
  • Plasmaz Mar 09, 2009
    I have the same problem im not sure if it is in warranty i took back a while ago because it started scratching my discs, does this mean my warranty is extended a year from when i took it back or will it of run out? I got it for christmas 2007 and it's over a year now so if I got an extended warranty from taking it back I should be able to take it back now, but if not it will be out of warranty.
  • Anonymous Mar 09, 2009
    same problem... I changed the settings so taht it loads to the cd instead of straight to the dasboard, but i bet its only a matter of time before it dies for good
  • Anonymous May 03, 2009
    my 360 will not even play a brand new gam that i just got.It just says open tray.
  • Mjoshuamcgil May 03, 2009
    i put a disc in is says reading then it just open disc tray
  • H-eraldi May 09, 2009
    when i put all discs in my xbox 360 it says open tray disc
  • Anonymous May 13, 2009
    same thing wrong with my xbox. im really sick of this ********!
  • Anonymous May 16, 2009
    I had my xbox say "open tray" bought a new drive from thumbmonkey.com and 2 weeks later it too says "open tray" once it has gone to open tray once it has never worked again.... ever. I think its deliberate
How I worked around the "Open Tray" problem, where the game discs were not being recognized:
1. Open tray
2. Unplug power cable while tray is open
3. Plug in power cable
4. Power on console - tray closes
5. Open tray
6. Insert disc
7. Try your game
Good luck! Source: Someone else mentioned this in a forum somewhere, however I don't recall who it was or which forum. I'm just trying to get the word out so people don't send in their XBOX for repair, or open the case and void the warranty if this workaround resolves the problem.
Posted on Sep 27, 2009
  • dvanhorne Dec 16, 2010
    dude, this totally worked. thanks.
  • dapo odinson Dec 19, 2010
    This worked absolutely first time for me!
Dude! i found a way that works, well for me , many of these problems have there own little quirks but, k i have the benQ disc drive which from my looking around are supposed to be less error prone than the samsung n hitachi versions, but so i took my xbox apart, voided my warrenty, really dumb, i know, but i didnt feel like waitin 2 months or how ever long microsoft would take so i popped that beast open n tried the rubber band trick and cleanin it with no luck, so i finally put my drive back together n ran the xbox opened up, while it was sayin reading i tapped on the top of the disc drive multiple times with a little bit of force, n i was expectin it to just say opn tray again but to my surprise it kept reading! no i shut off my xbox n tried this again n it works, so wow i guess microsoft products just need a kick in th a**, hope that helps sumone...
Posted on Sep 16, 2008
  • 3 more comments
  • romonaramour Oct 17, 2010
    Good advise, i did just what you said and by god it worked. thanks a lot.
  • ralpher90 Nov 22, 2010
    absolutly brilliant, thanks great fix!!!! just as said pop the game in knock above the diskdrive when it goes in, xbox flat on it side btw, and it works, just like knocking on some1's door!!!! thanks again!!!
  • jayyy252 Dec 11, 2010
    I agree with slapping the console a bit. I eventually get it going by doing that or slamming the tray shut really fast. But the next day it wud be same again, yet it worked all that day. Finally i decided it must be the heat that kept it working once u get it going. I now put it in my boiler press at night and so far it works every day. Its the cold that gets into it at night that brings it back to square one
  • steelerklyn Dec 17, 2010
    Dang! It worked for me. Thanks
  • r8ers54
    r8ers54 Feb 27, 2013
    it;s the laser lens replace it nd problem fixed
Ok, i have had this OPEN TRAY ERROR but i found out how to fix it without opening the xbox360.
what happened to me is : i turn my xbox360 on WITH a cd in the xbox and it said ''open tray'' but i soon found out that if you turn the xbox on with a cd ALREADY inside it will show the ''open tray'' what you do is make sure when you turn your xbox on there is no cd inside in the first place
if there is a cd inside simply turn xbox on take cd out turn xbox off then turn it back on DO NOT OPEN THE TRAY UNTIL IT HAS REACHED THE DASHBOARD !!! when it comes to dashboard put cd in then it should work it works for me.
Posted on Oct 07, 2009
  • 38 Answers
The inner ring on the dvd contains a decoding boot record just below where it says xbox in hologram on the dvd. Clean this inner circle below the xbox hologram so it will match up with the tag calculation and start up the .xbe file. ;)
Billy D
Posted on Apr 27, 2008
  • coolice44 Dec 25, 2010
    I cleaned the lens with alcohol and tested it and it worked, woot! However, when i put it all back together, it didn't work again, -very frustrated-. Then i tried hitting the thing and got an E-error but i turned it off again and gave it another few hits and it was gone. Since that wasn't working I went back and took it apart AGAIN and noticed the screws were lose on the DVD drive. I tightened the screws real tight and bang, it worked. Hope this helps!!!!
    New Friend:
I have had this error several times, and I have found 2 solutions. or come across 2 solutions rather. If you look up "Open Tray Error" you can find a video on YouTube detailing the cause of the "Open Tray Error" and a fix. So, before I talk about the cure, let me talk about the disease. The "Open Tray Error", theoretically, is caused when you have the disk drive open, and your xbox is turned off or the power source is removed. When your disk drive is open, the laser rides backwards on two rails out from under where the disc usually is in the closed position. However, when your xbox is turned off or the power source is removed, the laser does not reset. Now, if you are mechanically inclined you could follow the videos on how to disassemble your Xbox and fix your disk drive. I did this the first time I had this error, but after fidgeting with my xbox, I believe, I BELIEVE, that if you open your disk drive and turn off the xbox, after the drive closes by itself, turn the xbox back on, open the tray, and pull the power cord, then back in, and turn it on. I have tried the last method several times and it seems to work every time. Good Luck!
Posted on Dec 05, 2009
  • HisBobNess Sep 02, 2010
    Thanks. We tried this and it worked. We were about to take it apart.
    New Friend:
Just tap the top repeatedly while its reading. dont be gentle
Posted on May 22, 2010
    New Friend:
This is easy, just open and close the disk tray until it works. It usually takes about a half hour for me. It really builds the anticipation for a game!
Posted on Nov 24, 2009
I had the same problem, except that my xbox wouldnt play anything- I always got the "Open Tray" error. It wouldn't play any discs- no CD's, DVDs or Games. Since I was already out of warranty, I figured it couldn't hurt to open it up. It took me about 15 minutes to get the xbox all opened up (using guides on the Internet). Once inside, all I did was blow the dust out. Then I took a moistened Q tip and gently rubbed the laser eye in the DVD drive a few times. Then I put it back together. Not sure what I did, but its been working perfectly again... I haven't had the Open Tray error in over a week... Maybe my laser was just gunked up.
Posted on Dec 29, 2008
    New Friend:
Step 1. open tray
Step 2. take out disk
Step 3. put a movie in
Step 4. turn off xbox
Step 5. turn it back on
Step 6. wait until movie plays then go to dashboard and take it out
Step 7. put game in
Posted on Aug 30, 2010
  • gungraver21 Dec 22, 2010
    you know this guy who made tihs solotuion is a life saver i luv [email protected]#$%^
  • nicholas821 Jan 11, 2011
    not for me. i have tried almost everything on this website and still nothing ='[
    New Friend:
"open tray " error solution that worked for me.
take out the game and turn the system off and unplug it.
Plug it back in and turn the system back on (with NO game in it). when you get to the main screen it will say "open tray". press A to open it up and put in your game, then press A again to close it. Our game loaded fine. good luck!!
Posted on Dec 17, 2009
  • 27 Answers
Well actually all these "fixes" are not the problem.One day a friends console got the open tray error. after cleaning and all that i found that did absolutly nothing. after taking the entire drive apart i found that the laser / moter assembly was offset. this ment that the disk was tilted 1degree towards the laser and intern hittng the laser assembly that so many peopl think is "laser burn" which actualy is the disk physically hitting the laser. how u fix this is as easy as adjusting two screws were the moter and the laser/ tray assembly meat. now thses arnt nomal phillips, flat head or torx scews. i found that stickin a drill bit in the screw head annd turnin it with some pliers did the trick. this fixes the open tray error for good unless the disk is causing it. IF anyone gets open tray ocasionally this should stop it for good.
Posted on Jul 09, 2009
    New Friend:
Hey there, I blogged about this same problem and have a solution posted with a picture of the problem. See it here
http://bloggerboon.com/2010/01/08/xbox-360-says-open-tray-wont-play-game/
Posted on Jan 11, 2010
My Xbox 360 had this same problem, where it wouldn't play any game at all. So. I opened the disc tray and blew straight into the slot, similar to how you had to blow on game cartridges for old systems. It works fine now, and I didn't have to open it (and void the warranty) or send it to microsoft.
Posted on May 16, 2009
    New Friend:
Open tray error is a very easy fix hardest part is splitting the xbox after you split it remove the cd rom 4 screws hold a case around the internals remove the case push the laser as far towards the middle as you can take a small phillips head screw driver and turn the little gold screw on the left back side of the laser about 1/4 turn not much put it back togher and your back in action might want to check to make sure it works before you put it back togher just make sure you remove the magnet from the top of the cdrom case and use it to lock the game in place or you might be buying a new game
Posted on Jun 02, 2010
We tried all of these with the exception of voiding our warranty by opening it up - none worked. We finally took a hand vac and vacuumed all the vent holes and inside the tray and tray opening.WORKED !!!!!!! Game on !!!
Posted on Jan 14, 2010
VERY SIMPLE SOLUTION- Just open the tray take the cd out, close the tray empty, wait for it to settle,
Open it again put the cd back in then bobs your uncle!
Works every time for me!!
Posted on Feb 02, 2010
  • pumpkin93747 Dec 19, 2010
    you are awsome i was about to destroy the dang thing by blowing it up
    New Friend:
Mine said open tray when i tried to play it so i went to system settings then memory then press y to clear cache and what do you know it worked microsoft aint gettin my 150 dollars just clear the cache it should work
Posted on May 06, 2010
  • matt12882003 May 06, 2010
    try clearing cache
    New Friend:
Ya it was that last xboxlive update. Microsoft does this all the time: They send out an update that deliberately makes many xbox's malfunction. They make tons of money on new xbox's and reparis doing this.
I have same problem. Mine works by opening the drive and then closing it as soon as possible. I use the controller and just hit A twice in rapid succession. GIVE IT A TRY IT WORKS.
Posted on Jul 11, 2010
    New Friend:
Open the tray, blow it through with a hairdryer(warm), put the game in....works for me...god knows how!!
Posted on Jan 20, 2010
Hey just got home to play a sesh on gears 2 :D and the same problem happened!!!
i spent 20 minutes trying to get it to work and in the end did what foenix_down said above to just tug on the tray slightly, i just pulled the tray up/outwards slightly not too hard and then tryed again and it worked :D hope this helps anyone else out there
Posted on Mar 05, 2009
    Problem Solver:
  • 5 Answers
I had this issue... XBOX would not read ANY disc...
My warranty was expired anyway, so I decided to open up my precious...
I took out the DVD drive... opened IT up... Cleaned the lens... And...
POT TWEAK!
No, that's not some designer drug all the cool kids are doing, while you are trying to get Halo 3 to load...
If, and this is a BIG IF, you have and more importantly know how to use a multimeter... You might be in luck!
http://forums.afterdawn.com/thread_view.cfm/409908
Couldn't hurt right? Worked for me...
Posted on Apr 23, 2009
We have the open disk error and with a used xbox 360 we have no warenty so we opened it up and found out that after thining the laser twice for a fraction of a second it would say on the tv "open tray". after that we looked for the name of the drive ( GDR-3120L Xbox 360 DVD-ROM ). and are looking into getting a new or used one. thay can be found on ebay for $10 -$60+, not includeng shipping. hope this helps.
Posted on Jan 18, 2009
    New Friend:
  • 9 Answers
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
Posted on Jun 19, 2010
    New Friend:
I had the same problem. i had first gone to play Fallout 3 when i first got this. Then i tried like 4 other of my games and i still couldnt get any of them to work. The BEST soultion is not buy a new drive or try tampering with ur harddrive. i just went to best buy and bought a laser lens cleaner cd. The problem was getting the xbox to read it. i just kept turning it on and for about times until it finally said play dvd and just run a clean and my problem was gone for good.
Hope this helps
Posted on Jan 15, 2010
Hey i had this problem but i fixed it by opening and cleaning the xbox 360. I also cleaned the laser with a q-tip/cotton bud.
Cleared out all the dust and now it works fine. I use to only hav this problem for dvds then it happen to my games but now dvds work after i gave it a good clean. So try it and let me know if it wrks. But i still hav one other problem tray wont open if their aint no game inside
Posted on Nov 02, 2008
    New Friend:
I have had this problem with trying different things but what are the odds that i changed the Machine setting and disabled autoplay of cd's and now my games are working .. try it out and see what happens
Posted on Jul 25, 2010
    New Friend:
Thanx much Matt. I just cleared the cache and it is working now. I would suggest trying that 1st. worked 4 me
Posted on May 20, 2010
    New Friend:
Take out HD and replace
clean disc thoroughly including hologrammed center
check all connections to and from tv
blow dry air into open tray, either by mouth or air canister
Posted on Feb 15, 2010
    New Friend:
I had same problem with my xbox couple months before.
Use this guide for detailed instructions and solve it yourself without paying too much.
Good luck.
    Welcome Back:
    Visited the website for 2 consecutive days.
This fix is probably the best fix because it has worked the most times for me.
So all you'll want to do is put a disc in the disc drive, close it and wait for it to load. If it says "open tray", open and close the tray again. Now keep doing this. It should eventually load the disc. But keep trying for at least 5 minutes straight.
check for other methods here
https://www.errorsolutions.tech/error/xbox-360-open-tray-error/
Posted on May 16, 2018
    New Friend:
I stripped the x box down and cleaned all the gubbins inside. Used a cotton bud to clean the laser carefully. Sorted!!
Posted on Apr 13, 2013
    New Friend:
Okay,your warranty is out. You have no cash, no friends to help, no video on youtube seems to help. Try this; since your gonna open the thing anyway.
Disassemble disc drive.
Remove gray disc tray and flip it over and check for trash on gear grooves. Also look for anything that could burred up, broken off. There is a tab on the gear assembly that shifts left & right for open and close positions of the tray. This gear travels down a path that
steps down to a closing and 'raising' the laser into the 'ready to run' position. Besides having weakened metal contact bars that need repositioning for better operation[on well used drives] this tab does not quite make it to the correct spot. Therefore not allowing the laser to be ready for reading a disc - Disc reading error.
I tried to superglue a piece of old credit card material in there but I haven't perfected this,yet. I replaced the tray with another one that was not damaged and it worked perfectly.
Clean lens with Q tip & alcohol as well as rails & corkscrew shaft. With closed tray make sure it slides smoothly.
Don't get in a hurry putting the drive back in the xbox. You could have it sitting incorrectly and still have the error. Be sure to spray clean the eject button on the circuit board thoroughly. Make sure your plastic eject lever is lined-up properly upon assembly. Or you'll be 'no better than a monkey' and 'bang on it' to get it working.
Posted on Nov 30, 2012
    New Friend:
  • 16 Answers
This worked for my xbox http://howtofixstuff.blogspot.com/2012/01/how-to-fix-xbox-360-open-tray-error.html but you got to know what your doing or else you will be lost
Posted on Jan 11, 2012
    New Friend:
THIS SOLUTION DOES NOT REQUIRE OPENING THE Xbox 360
The open tray error is one of the more common in Xbox 360's. Before I tell you how to fix it I will tell you a common theory as to how this happened. If you don't want to read this skip to the next space in-between paragraphs. Now my theory. Inside the Xbox 360 there is a laser eye that moves up and down the disc to read it. Sometimes if you shut down the Xbox 360 while it is still playing a game the laser eye will be stuck on the very end of the disc and will not be able to read the disc. The only way to fix this problem is to get the laser eye back where it can read the disc.
I have tried every single way mentioned to fix my Xbox 360 (that hasn't required opening it) and this is the only one that I discovered that worked. First you must try to see if any of your discs take a few seconds longer to go from "Reading.." to "Open Tray" if you do find a disc that you own that does this then keep on having it "read" the disc (open and close the disc drive). After three to seven minutes the disc will change from "Reading.." to "Play game" and the game should start. The only games I have seen this work so far with are "Lost Planet" and "Assassin's Creed Brotherhood". Please comment if this also worked for you or if you have found any other games that this works with.
Posted on Mar 25, 2011
    New Friend:
REALLY EASY AND IT WORKS
  • Get a Paperclip and bend it so it makes a hook
  • Stick it in your drive and pull the lens towards you
  • MAKE SURE THE XBOX IS OFF, to do so just pull the plug while the drive is open
Posted on Jan 01, 2011
IF there is a buybacks near you, you can take it there. They charge $3, but only if they get ALL the scratches out. If not it's free.
    New Friend:
I tool my XBOX 360 apart and cleaned it. That didn't work, so I opened it back up and got to the laser part of it. There is a tiny screw holding a white guide on the little bar that the laser slides up and down on. I loosened that up a little and tightened it back down, but not as tight as before and now it works fine! seems the laser gets stuck because the screw is to tight.
Posted on Oct 01, 2010
    New Friend:
Its a pretty easy fix guys. I have had the same problem and fixed it with no problem at all. Your lens is dirty on you disk drive and needs to be cleaned off. There is also a little trick that when you put the game in and close the tray you kind of hit or tap the top of your xbox above the disk drive while the system is reading your game. If you hit it in the right spot the system willl continue to load up the game like normal.
But the legit way to fix the problem is by opening up the console and pop out the cd drive which is quite simple all you have to do is pull out the wire in the back so that you can work on the drive.
Now unscrew the drive so that you can get to the lens and clean it off with a Q-tip and a tiny bit of alchohol. I just dipped a qtip in a little bit of it and the wiped the lens very lightly so that you dont screw up the alignment of the lens itself... Once your done with that maybe just wipe down the inside cover of the drive to help future dirt and close it all back up and your good to go.....
Posted on Sep 21, 2010
  • steelshed Oct 15, 2010
    thanks mate .will try cleaning
    New Friend:
    Problem Solver:
  • 6 Answers
Yeh i have this problem too but my games work without doing anything really ok at first i got really annoyed and i kept opening and closeing it and after the first 100 times the game came on it annoys me because it starts to read longer then still says open tray then finally works anyway it got worser so i called my uncle round hes like a intense gamer so he told me it was getting over heated plus i read on the internet that theres a laser that can burn out and that will cause it anyways ive made it cooler and it work quicker but still had the open tray problem now i annoyed again because the problems back but longer than b4 just now i opened it like 1000 times and it works so JUST KEEP OPENING AND CLOSEING IT OK :)
Posted on Aug 09, 2010
    New Friend:
All i did was open up the box, tooke the case off the dvd drive, cleaned the laser with rubbin alcohol which didnt fix anything but i figured it needed a cleaning anyway, and then adjusted the tightness of the dvd drives lid and kept testing discs until it read one, then successfully read it over and over again, while every now and then it still recognized it as a dvd isntead of a game, but the point is it worked. :D
Posted on Apr 18, 2010
    New Friend:
Ok, so heres a cheap method of fixing this error. There is no opening of the xbox 360. You just get a canister of compressed air like what you use for a computer.
Now you have to open the disk tray and spray into the xbox. Also spray the vents. It'll read for longer then usual and then you have a working xbox
Posted on Oct 09, 2010
    New Friend:
Open the tray
insert the game
push the try softly by your hand not by using the button
it worked form me
Posted on Sep 24, 2010
Turn the xbox on its side so it stands upright .... worked on multiple consoles for me :)
Posted on Mar 12, 2010
    New Friend:
I only have atemporary solution for this problem
1. take apart xbox and vois warranty ( dont do this if u want to send it to MS.
2. move lens to the correct starting point, this is the cause of the open tray problem.
3. once u move the lens (its on parrallel runners) to the right starting point it will work but it is only temporary
http://www.youtube.com/watch?v=ycuvX7x1HJk
then u have to put it back together
good luck this works but it is a pain to repetitively take the xbox apart and keep doin it
Just clean disc with some soft thing close x box 360 turn off ALL power then turn on tv open xbox
insert game wait and there u go worked on mine it aint up to cd much just minor stuff like dust
Posted on Aug 25, 2009
  • 55 Answers
There are all kinds of gimicks and "scratch removers" or "resurfacers" that you can try. if any of them work is up to your level of patience and how much money you're willing to waste on it.
IMO it would be cheaper to buy a new copy of guitar hero than the effort and $$ to try and salvage a destroyed disc.
BTW, I heard clear nail polish works. ;)
Posted on Mar 25, 2008
4 Suggested Answers
SOURCE:
SOURCE: Discs won't start up when put in the Xbox 360
i had this before a few times, nt sure if it will work 4 u guys. when this happens what i done was that
i got my xbox (no disc inside it)
turned it on horizontal
made the console vertical (whilst still running)
and then back to horizontal again (whilst still running)
then turn it off
turn it on again, stick any game in and it should work. thats what i done when mine got broke. best of luck. if it doesn't work, take it Microsoft.
Posted on May 18, 2009
  • 11 Answers
SOURCE: xbox 360 reads open tray and doesn't show game
Just keep closing and opening the tray, sooner or later it should read the disk.
  • 9 Answers
SOURCE: when i put a game in my xbox 360 it says reading then open tray
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
My guitar hero world tour will not load past the screen with the earth spinning around. i have tried cleaning the cd but i dont think this is the problem
Hello, If you have no scratches on the disc and you are still having issues, then chances are that your xbox360 DVD/CD reader is failing.
You can go to xboxlive.com and check your warranty status. If it is under warranty you can open a case online that they will send you a box so you can ship your xbox back to Microsoft for repair.
Hope it helps
Feb 28, 2011 | Buck Guitar Hero World Tour for for Xbox...
My Ps2 guitar hero plays Guitar hero #3 perfectly fine, but the other one Guitar Hero Rocks the 80's wont play at all. We were not able to get the World Tour to play at all. What gives?
Check the bottom of the disc it may be dirty or scratched. If its dirty then clean it with rubbing alcohol, if scratched you'll have to buy a scratch remover.
Dec 19, 2009 | Sony PlayStation 2 (PS2) Console
Game disc cannot be read on the wii
Make sure you haven't scratched the disc. even 1 scratch might put it out of operation. if not, grab a drive cleaner, they have little brushes on them, and may clean your wii lens.
Aug 15, 2009 | Nintendo Guitar Hero: Aerosmith for Wii
Guitar Hero Metallica Wont play on my Ps2
okay, try this: 1. Start up PS2 with no disc 2. select 'Browser', press triangle. 3. select 'Console', press triangle. 4. select 'Diagnostics', press X, select 'ON'. 5. press 'O' to back out of this menu. 6. select 'Playstation Drive', press triangle. 7. select 'Disc Speed', press X, select 'FAST'. 8. press 'O' to back out of menu. 9. turn off PS2. 10. insert disc. The Diagnostics should run and automatically adjust your PS2 to play the game. I got this "FIX" from someone who had the same problem. Hope this helps :D
Jun 09, 2009 | Sony PlayStation 2 (PS2) Console
Troble with x box
Same thing happened to me bro.. look at the disc, if it is scratched, get anew one....
Jan 21, 2009 | Activision Guitar Hero: Aerosmith for Xbox...
Guitar hero 3 main menu won't load
Get a cd cleaning cd and run in on the PS2 will work fine then
the ps2 just cant find the menu in diffrent spot
just use the cd cleaning disc and all shall b fine
Aug 16, 2008 | RedOctane Guitar Hero 3 - Legends of Rock
Guitar Hero III for the Wii
I had the same problem for my playstation 2 with that game. All you have to od is clean the lens of the games console. Then it should work fine
Jun 15, 2008 | Video Game Consoles & Games
Xbox cant read disc
check and see if the disk is scratched. if there are scratches, follow these directions:
take your game disk and with Colgate (preferred) toothpaste (not gel, use the white thick stuff).
squeeze a small amount of toothpaste unto the disk's reflective surface (part with scratches) and smooth it on in a circular motion, applying more when necessary. you want to have it on at least a little bit thick, so it covers the whole surface. leave the toothpaste on for about 5 minutes and then rinse it with lukewarm water, making sure all the toothpaste is off. You will likely still notice a few scratches but most will have disappeared.
stick your disk back into your 360 and load the game. with any luck it will load! =)
if this doesn't work, contact xbox customer support at 1-800-4MY-XBOX
Dec 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
118,196 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
