Question about GPS
Handheld PDA field data collection (with GPS) - need advice
I would like to use handheld computers with built-in GPS or an external GPS device to record waypoints in the field, and also enter some related data. Below is my dream wish list.... I would appreciate your input on what platform you recommend for this.
- simple form to collect 10-15 fields of data using mainly drop-down boxes
- each time a record is created, the current GPS coordinates are recorded
- the data can be downloaded into an Access database
- ultimately it would be cool if the device could also take a photograph and associate the photo with that record
I have some limited exposure to Pendragon forms running on older Palm technology - but I would like to learn of technology improvements since then.
I am very experienced with VBA and Access and SQL. It would be ideal to be able to leverage these skills instead of learning new proprietary scripting languages, but I will if I have to.
Thanks for your input.
Noggin
  • 944 Answers
SOURCE: Plotting Waypoints
Here's the link to the user manual if you need it; http://www8.garmin.com/manuals/GPS60_OwnersManual.pdf Garmin says; To manually enter in the coordinates for a waypoint on the 60 or 76 -series units, use the following steps: Press and hold the 'Mark' button. Use the up arrow to scroll up to the "Location" field and press 'Enter'. A new box pops up to enter in the new coordinates. Go to "OK" and press 'Enter'. Select "OK" at the bottom right corner to save all changes. Hope this helps :)
Posted on Jul 17, 2007
daverh
  • 117 Answers
SOURCE: connecting html form to Ms-access data base
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Posted on Sep 29, 2007
  • 638 Answers
SOURCE: eTrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Posted on Apr 01, 2008
  • 359 Answers
SOURCE: restict closing the main form when some controls on the subform are empty
Hi there. I didn't notice this was so old until I had already worked on it for some time. Did you get this the way you want it? If not, I suggest either using a BeforeUpdate control to ensure the condition is met that the subform contain data, or validate the particular field(s) with isnull. Thanks for posting back if you still need help, or otherwise rating FixYa!
Posted on May 05, 2008
SOURCE: using drop-down form field in a word 2007 template
You need to protect the form (Protect Document, Editing Restrictions (Filling in Forms) then Start Enforcing Protection, the drop down menu will then work.
Posted on Sep 29, 2008
What are the codes for Samsung Android phone
Samsung secret code by Mubarak Sulaimon
*#06# - IMEI number
*#0*# - Enter the service menu on newer phones like Galaxy S III
*#*#4636#*#* - Phone information, usage statistics and battery
*#*#34971539#*#* - Detailed camera information
*#*#273282*255*663282*#*#* - Immediate backup of all media files
*#*#197328640#*#* - Enable test mode for service
*#*#232339#*#* - Wireless LAN tests
*#*#0842#*#* - Backlight/vibration test
*#*#2664#*#* - Test the touchscreen
*#*#1111#*#* - FTA software version (1234 in the same code will give PDA and firmware version)
*#12580*369# - Software and hardware info
*#9090# - Diagnostic configuration
*#872564# - USB logging control
*#9900# - System dump mode
*#301279# - HSDPA/HSUPA Control Menu
*#7465625# - View phone lock status
*#*#7780#*#* - Reset the /data partition to factory state
*2767*3855# - Format device to factory state (will delete everything on phone)
##7764726 - Hidden service menu for Motorola Droid
Update x1: More codes!
*#*#7594#*#* - Enable direct powering down of device once this code is entered
*#*#273283*255*663282*#*#* - Make a quick backup of all the media files on your Android device
*#*#232338#*#* - Shows Wi-Fi MAC address
*#*#1472365#*#* - Perform a quick GPS test
*#*#1575#*#* - For a more advanced GPS test
*#*#0283#*#* - Perform a packet loopback test
*#*#0*#*#* - Run an LCD display test
*#*#0289#*#* - Run Audio test
*#*#2663#*#* - Show device's touch-screen version
*#*#0588#*#* - Perform a proximity sensor test
*#*#3264#*#* - Show RAM version
*#*#232331#*#* - Run Bluetooth test
*#*#232337#*# - Show device's Bluetooth address
*#*#7262626#*#* - Perform a field test
*#*#8255#*#* - Monitor Google Talk service
*#*#4986*2650468#*#* - Show Phone, Hardware, PDA, RF Call Date firmware info
*#*#1234#*#* - Show PDA and Phone firmware info
*#*#2222#*#* - Show FTA Hardware version
*#*#44336#*#* - Show Build time and change list number
*#*#8351#*#* - Enable voice dialing log mode, dial *#*#8350#*#* to disable it
##778 (+call) - Show EPST menu
These codes are specific to HTC devices only:
*#*#3424#*#* - Run HTC function test program
*#*#4636#*#* - Show HTC info menu
##8626337# - Run VOCODER
##33284# - Perform field test
*#*#8255#*#* - Launch Google Talk service monitor
##3424# - Run diagnostic mode
##3282# - Show EPST menu
##786# - Reverse Logistics Support
WLAN, GPS and Bluetooth Test Codes:
*#*#232339#*#* OR *#*#526#*#* OR *#*#528#*#* - WLAN test (Use "Menu" button to start various tests)
*#*#232338#*#* - Shows WiFi MAC address
*#*#1472365#*#* - GPS test
*#*#1575#*#* - Another GPS test
*#*#232331#*#* - Bluetooth test
*#*#232337#*# - Shows Bluetooth device address
*#*#8255#*#*
This code can be used to launch GTalk Service Monitor.
Codes to get Firmware version information:
*#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate
*#*#1234#*#* - PDA and Phone
*#*#1111#*#* - FTA SW Version
*#*#2222#*#* - FTA HW Version
*#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number
Codes to launch various Factory Tests:
*#*#0283#*#* - Packet Loopback
*#*#0*#*#* - LCD test
*#*#0673#*#* OR *#*#0289#*#* - Melody test
*#*#0842#*#* - Device test (Vibration test and BackLight test)
*#*#2663#*#* - Touch screen version
*#*#2664#*#* - Touch screen test
*#*#0588#*#* - Proximity sensor test
*#*#3264#*#* - RAM version
May 04, 2016 | Samsung Cell Phones
I have a Handspring Visor Graphite Handheld and when i shnged the bateries i lost all my data. Anyone can help?
If you have hotsynced your Visor with a PC (or Mac), the first time you sync your Visor to that computer, it should restore all the data from the last hotsync to the PDA. This is one big reason that it makes sense to sync your PDA on a regular basis.
Unfortunately, if you never used the hotsync function for your Visor, you may not be able to recover any of your data. This model Handspring Visor requires good batteries or else everything in its memory will randomize and you will lose all stored information. There is a small capacitor in the Visor that provides enough reserve power for about 30-60 seconds when you pull out the batteries. It's for this reason that Palm recommended pulling out only one battery at a time when changing to a fresh set. That minimized the amount of time that the PDA would be without power. That same advice applies equally to Visor PDAs.
Jun 15, 2011 | Handspring Visor Graphite Handheld
My computer crashed. I have a backup of all my Palm files but am having trouble recovering them. Does anyone have instructions on how to restore backup files on a Palm Tungsten E2?
Hello.
Palm backups are located in the following directory: C:\Program Files\Palm\username>\ED\Backup\
When you HotSync a PDA that has undergone a hard reset, HotSync will compare the two devices. When it sees that the PDA is empty, it will attempt to reload any backup that exists on the PC. Once this data is reloaded, the PDA will ask to do a soft reset. This is simply a restart of the device and doesn't affect any of the newly installed data. This returns the PDA to working order, with all the data and programs functioning as they were before.
Hope this resolves your problem.
Jan 23, 2011 | Palm Tungsten E2 Handheld
The GPSmap76CSx unite stopped finding any satellite signal.
try to use external antenna, if signal is back then probably internal built-in is damage.
Jan 12, 2011 | Garmin GPSMAP 76CSx Handheld GPS GPS...
When trying to synchronize with PC an error box comes up with a message-"Error occurred while copying datablocks from handheld.This key is already associated with an element of this collection 457".
The person who supplied the program I was using advised me it was an error related to the date on the PDA. ( Something to do with Julian Calendars etc.) I use the PDA to transfer data from a soil moisture logger to my PC.
First I cleared all data from the PDA.
Then I loaded up the data (with correct date) from the PC to the PDA, and went out and restarted all the loggers.
I haven't done another reading yet, but if that worked I'll letyou know.
Regards,pvhoff.
Feb 09, 2010 | HP iPAQ HX2700 Pocket PC
It says i have no connection between my handheld and my computer when i try to hot sync
If you are trying to HotSync to a Macintosh, you need to install Lycestra's PDiQue software available at http://www.lycestra.com/ique.html before HotSyncing is enabled. PDiQue enables a USB conduit between your Mac and the Garmin iQue 3600.
Oct 23, 2009 | Garmin iQue 3600 GPS Receiver
I have external GPS button in my HTC touch p3452 pda . . how to get get gps data from this ??
u need an external gps device bought separately and then trhu bluetooth u can communicate with this software in ur HTC , u have external bluetooth device or not
nowdays GPS is coming builtin so there is no need to purchase separate reciever but in ur PDA it is not built in
pls rate me WELL for info !
May 20, 2009 | HTC Touch P3452 Smartphone
I need to replace battery. Is it easy to get back off? Manual says I need to take it to repair shop
Basically to take any phone or pda apart, unscrew all screws and look for hidden screws under soft objects or labels etc.
ones all screws are out, use a small flat screwdriver or a case opener tool to carefully open the case of the phone or pda. it should snap open, very likely plastic holders on the corners that keep the case closed, carefully snap them open / off, don't break them.
May 13, 2009 | Mitac MIO P350 PDA POC PC+ GPS SAT NAV...
What is a sd card ?
Secure Digital (SD) is a non-volatile memory card format developed by Matsushita, SanDisk, and Toshiba for use in portable devices. Today it is widely used in digital cameras, handheld computers, PDAs, mobile phones, GPS receivers, and video game consoles. Standard SD card capacities range from 4 MB to 4 GB, and for high capacity SDHC cards from 4 GB to 32 GB as of 2008.
Jan 24, 2009 | Computers & Internet
Cant get it to work
If this is an IQue 3600 then you will need to install the Palm Desktop from your original IQue disk in order to sync with your new laptop. The Microsoft active-sync is for a PDA using Windows (Garmin M3 and M5 are windows based PDA w/GPS).
May 09, 2007 | Garmin iQue 3600 GPS Receiver
GPS Logo
52 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
