Question about Ariens 34 In. Zoom Series Riding Mower
Where can i get an ARIENS drive belt, new or used
  • 2,841 Answers
Anyplace that sells Ariens mowers will have one. Most other lawn mower stores can also sell you one. Remove the old belt and take that and the model Airens you have to get a replacement. You do not want a used belt just get a new one.
Posted on May 01, 2010
Having trouble removing drive belt
Remove belt from opposite end so you don't fight with clutch end.
Jul 02, 2015 | Ariens Max Zoom 60 in. 25 HP Kohler...
What is the drive belt size for Ariens 42 tractor and diagram to install
The belt number on the back of the belt will have the size. If you can't read it and the belt is broken without any missing peices
then lay it flat and measure its length.
Jun 10, 2015 | Ariens Garden
How does the drive belt go around the pully system on an Ariens lawn tractor
Go to this site:
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.5721913612416231&Site=ARIENSS
Aug 02, 2014 | Ariens Garden
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link: Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Jul 14, 2014 | Ariens 34 In. Zoom Series Riding Mower
Ariens Hydro ride on mower, Blade Drive Belt will not stay on Pulleys
Are you sure it is the right belt? Is the tightener working properly Are the pulleys miss aligned?
Nov 05, 2017 | Ariens Garden
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens 34 In. Zoom Series Riding Mower Logo
270 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
