Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Security light stays on and somtimes it will turn over but wont start i wait half hour and it will start but then shortly after securty light comes on and wont go off. help
  • yadayada
    yadayada May 11, 2010
    do a VATS bypass.
    Novelist:
  • 355 Answers
The security system (VATS/PassKey) is having problems, it's typical on those cars. You can find a great write-up here: http://newrockies.ca , it was the only thing that saved my Park Avenue.
Posted on Sep 10, 2010
Lexus ls 400 1996 flat batteriy ok now but security light on found away to start the car but every time i turn the key off securty light comes back on
FLAT batterY?? Battery OK,now? New one? Old one OK?HUH?
Get security codes FIRST: radio and NAV.
Disconnect battery from car and wait for 30 seconds and turn on the headlight switch,DURING the battery disconnect.
Turn off the headlights and reconnect the battery.
the security system should "re-boot" and be happy.
then there is the radio issue, Get the code.....
Nov 14, 2012 | Lexus Cars & Trucks
Engen light oonly comes on somtimes on dash not on no start
sounds like a short in your ECM. (electronic control module) the computer that runs your systems. it also runs the check engine light and lets you know when a sensor or something isnt working. you will need a good mechanic that knows how to do the electronics in a car.
Jan 11, 2012 | 1993 Jeep Grand Cherokee
My 2002 Alero wont start and the security light stay on. ive tried turning the key on, waiting 10 minutes, turning the key off, and then starting it but nothing happens. nothing is working. what should i...
Since you've tried the 10 minute relearn process with no luck, Try this same process 3 x in a row without trying to start in between. Will take a little over a half hour. If this still does not work, and the security light is solid (not flashing) this indicates a bad TDM. (passlock security computer)(Theft Deterrent Module). A new one will cost about 700 bucks. But this entire system is able to be bypassed permanently. If all else fails, check out this link. Its full of info on how the system works, along with "do it yourself" ways to fix it. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 21, 2011 | 2002 Oldsmobile Alero
95 chevy lumina cranks but wont start, no spark, replaced the crank senser, no luck
Are there any lights on the dash when this happens? When you put key in and try to crank it over, does the securty light come on?
Apr 10, 2011 | 1995 Chevrolet Lumina
Light comes on staying on saying check securty system what does details
The problem is your Vats security system. This causes the car to either "not start" or "shut down" while running. (depending on the system) If the security light flashes, i guarantee that this is what the problem is. 1st trick, (if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start.
Cheap fix:
----- http://vats.likeabigdog.com/
----- Bypassing the key
Never worry again fix:
----- http://newrockies.ca?ap_id=judd0081
----- With this fix, you can take that whole Vats, passlock, passkey **** system out of your car all together. Good info on both sites read up on this stuff, if that lights coming on, its gunna fail soon
Jan 12, 2011 | 2000 Cadillac Seville
Securty light is on wont start
no good you will have to take to dealer to remap securty or sometimes turn key forward accessories only wait for light to turn off few up to fifteen minutes
Oct 02, 2010 | 1994 Pontiac Grand Prix
My dash lights are on and the truck won't turn over.
you have water leaking into the fuse box causing a short cicuit , inspect the fuse box's, inside car and in engine compartment and see which one is getting wet , will look rusty, maybe still have some water left in it etc , then find the leak
Jun 03, 2017 | 2001 Ford Expedition
I just change the key lock on my chevy 2003, and now wont star it star but it wont stay runing
did your old cylinder have wires coming out of it ? did your old key have a chip in it is your security light on? if so the vechicle will not start
Nov 12, 2009 | 1996 Chevrolet Cavalier
Battery light on, takes forever to start then dies once started
if you can get the car started again and with someone helping you have them take the positive side of the battery cable off while it is running and if it dies then it is the alternator also check your drive belt and when was the last time it was changed because it could be slipping
Jan 05, 2009 | Lincoln Mark VIII Cars & Trucks
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
182 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
