Horizonal line in monitor screen cant seem to adjust
    Scholar:
  • 64 Answers
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. ry the following steps:
    3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. let me know if this resolved ur issue.. got plenty of resources to help u out.. regards guru
Posted on May 05, 2010
My computer screen is going down
Sounds like you need to do a realignment to your picture on your monitor, look on the front panel on you monitor for a menu button, press it, just once wait for the menu to come up, the you should see arrow keys next to the menu button, scrowl down until you find Horizonal adjust, they may call it something else, follow the instructions on the screen to make the nessary adjustments, you can adjust brightness and contrast also. Thanks Rick
Jul 31, 2011 | LG Studioworks 700S 17" CRT Monitor
Horizontal lines have started appearing, running all he way across the monitor screen....several close together abour 3 inches from the top, and one, sometimes two, about an inch from the bottom... I have...
what you are seeing ithe horizonal sync lines, have you tried to adjust the settings on this monitor, I would try turning down the brightness, and the contrast. There should be a menu button on the monitor to adjust it.
Nov 18, 2010 | Soyo DYLM2286 Monitor
Stretched picture
Go to "control panel" dbl clk "display" then adjust "Resoloution" example:724x1028 something that looks like that,just keep trying sizes until u get what u want. Goodluck!
May 28, 2010 | Compaq 17" Flat Screen CRT Monitor
The screen has lines and double vertical images then horizonal black lines form and no image is there - a virus?
there is no virus. the problem is the screen. you need to replace it with new screen or let if fix by a technician. they will replace the vertical and horizontal transistor. or so.
Mar 05, 2010 | Acer AL1715 17" LCD Monitor
Horizonal lines
Unfortunately you can't.
This is what happens when you blow pixels on your monitor.
If it is still in warranty this will be covered.
If you are outside of your warranty then you will need a new monitor
Sep 26, 2009 | Acer AL1916W 19" LCD Monitor
923nw samsung resolution problem
on ooptions screen, click box that says only show settings the monitor can handle. Then try changing the horizonal and vertical settings on monitor to match it up with your settings.
On your windows main screen, right click, then properties, then settings, check all the settings
Jul 09, 2009 | Samsung 923NW 19" LCD Monitor
Screen is covered with horizonal multicolored lines.
1st and least expensive is to replace the video connection cable. Try that
Cheers!
Mar 26, 2009 | Sceptre x22wg Gamer Monitor
Rolling horizontal line on screen
What was the reason for aquiring a new monitor?
Nov 23, 2008 | LG Computers & Internet
My samsung 910 Monitor has horizonal lines going through the picture***
If the lines are stationary then the damage may be in the screen itself
IF in just a part of the screen that may not be fixable.
If covering the entire screen, then check to see if the screen has a ribbon on the rear connecting the top board to the side board.
Check the ribbon that goes from the video board to the back of the screen, see if moving it about changes anything.
If the lines move up and down, then the problem may be in the video card itself. This usually isn't fixable or should I say not worth the cost to fix if you can find someone that does video chips.
ebaysbammbammfran
Oct 11, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Screen has red lines
try to reset default setting on monitor
Jan 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
