Question about Siemens Washing Machines
Cannot clean pump on my siemens s 16-76 cant open the pump
Siemens WE61021GB/01 displays error code 03
http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
    1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals. 2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it. 3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual. 4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
Aug 11, 2014 | Siemens WE61021GB Front Load Washer
Siemens washing machine keeps washing
Hi Linda Bailey,
If it keeps washing it could be that it is unable to progress to the Drain or Spin cycle. The likely culprit could be the Drain Pump Filter. To clean the Drain pump filter:
1) Plug the appliance out.
2) Open the small compartment below the door (Either Right or left hand corner) You will see a small pipe and a circular lid with a handle.
3) Drain the water by using the small pipe (Get a bowl for the water!), take of the cap of the hose or use the tap on the pipe on some models.
4) Once all the water is drained, open up the cap (Again.. Keep the bowl close by for spillage) by turning it anti-clockwise. Once off, clean the filter which is found on the cap.
5) stick your fingers into the now open compartment, be sure to clean out any obstructions, and feel if the impeller inside can turn freely.
THATS it! Now re-insert the cap, and close the pipe if open. Plug your machine in and viola!
It should solve your problem.
If not, let me know.
Kind Regards
JEDEMEYER1
Oct 03, 2011 | Siemens WM14S794GB Front Load Washer
Need english manual for xlm124a washing machine
while everytime i go to there it says cant find page here is the link to siemens home appliances where you could downlad manual if page opens
http://www.siemens-home.com/
Jul 25, 2011 | Siemens Washing Machines
Comes up on readout the pump blocked cant find type siemens washing machine(S 16-74)
This video will show you how to check the pump and we have other videos on how to change the washing machine pump if it needs replacing
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Siemens Washing Machines
My siemens dishwasher is not working, The pump that you hear in the begining of the cylce, is running (even when I open the door) but it will not go to the next cycle of filling with water. We did have our...
the control computer is bad. the relay on the control for the pump is stuck. if its less then 5 years old it should be under warrnty. look for your owner book. find the warrnty section. it should have a service number to call.
Jan 10, 2011 | Siemens SL85A705UC 24 in. Built-in...
Dishwasher siemens is not draining water.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Siemens WFXD8400UC Front Load Washer
Siemens Condensor Dryer E46-38. After a few
Mine is 4 years old and the pump went within 8 months! The dryer has had 6 new pumps in total! It was last fixed 6 months ago and now playing up again! I dont even constantly use my dryer! I am very disappointed with Siemens now, my last dryer lasted me 10 years and it was constantly on the go when my children were young! Here comes, tomorrow I have got to book another repair! No more Siemens for me.
Oct 20, 2009 | Siemens Dryers
My siemens frontload washer is not draining -
You need to remove the filter and clean it, also make sure that you clean the filter receptacle on the machine and check the waste hose that leads out of the machine and check it for kinks that might be restriting flow, refer tothe image below for further assistance:
Jul 06, 2009 | Siemens WM14S794GB Front Load Washer
Siemens 1433 Washer - Aquastop
I had the "pump blocked" message, and we had the pump replaced after the technician took a look. He said the washer had been overused (we had run it 4 times a day for 8 months).
Jan 13, 2008 | Siemens WIQ1433 Front Load Washer
Washing Machines Logo
643 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
