Question about Sony STR-DE545 Receiver
My receiver clicks on a off randomly.
It starts working and then makes a click sound and the audio turns off.
I used to be able to hit the top of the receiver and get it to turn back on, but no longer
  • 25 Answers
Hello Fixya customer,
Thank you for your question.
Are you getting on the display, possibly a "P" or "Protect" that indicates it is in the protect mode?
Hitting the top of the receiver indicates a possible intermittent component or board connection. The receiver will shut down when the Microprocessor receives various fault conditions, including shorted speaker and wires, but if it develops an internal fault it will also shut down to protect itself and the speakers.
Remove all speaker wires and inspect th terminals for any stray wires shorting the terminals.
If it still shuts down, then a professional servicer would be required.
Thanks for using Fixya, and if I can help you further, please let me know.
Posted on May 01, 2010
My Microphone was makeing a humming noise... so I turned it off now I need to use it and it is no where to be found! Please help!
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then
You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
Make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select
properties at the bottom select use this device enable
Hope this helps.
Nov 14, 2012 | ASUS Eee Top ET2400INT-B121E 23.6-Inch...
How to detect microphone in laptop
I think it would be better if we check that the built-in microphone is working on your machine.
Internal microphone
The internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to better capture sound with the microphone.
-Adjust the notebook PC screen to place the microphone in the best direction for receiving sound.
-Speak directly into the microphone. Avoid speaking away from the microphone.
-When using the internal microphone, choose an environment without background noise.
Testing the record function on the notebook PC
1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
2. Click Record (the red dot) and speak into the microphone.
3. When you are finished recording, click Stop (the gray rectangle).
4. To play back the recording, click Play (the gray arrow pointing to the right).
If happens that the recording with the microphone have no sound we have check the settings.
Checking microphone settings
1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .
2. A Volume Control or Master Volume window opens.
3. Click Options , and then Properties .
4. Select Recording , and make sure Microphone is selected.
5. Click OK . The Volume Control window should change to a Recording Gain Control window.
6. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
7. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step
Ensuring the correct recording device is selected
1. Access sound properties:
-In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
-In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
2. Click the Audio tab.
3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
5. Click OK .
6. Close the Sound and Multimedia Properties window and test the recording.
Feel free to reply if happens the steps I've told you is not working. Hope it helps.
AnEspera
May 03, 2011 | HP Pavilion dv4000 Notebook
How can I turn off the sounds the keyboard makes when you hit certain keys...for instance the caps button makes a loud beep..I thought I remember when i set this keyboard I had the option of having the...
Try this Go to start click control panel and then click sounds and audio devices and click the tab named sounds and in the sound scheme click the drop down menu and select no sounds and then click on apply and click ok ..Check whether it works
Mar 08, 2011 | Gear Head WIRELESS keyboard/Mouse
Pc sound is not working right now hepl me
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
I HAVE PROBLEM IN CONNECTING MY LAP TOP COMPUTER WITH AUDIO VIDEO CASSETTE RECORDER BY DYNEX 3.5mm STEREO AUDIO extension cable
Connect the "audio-output" (LEFT/RIGHT) channels from the A/V cassette-recorder to the "line-in" (LEFT/RIGHT) port on your computer.
Click the Windows START button.
Click All Programs.
Click Accessories.
Click Entertainment.
Click Sound Recorder.
Click Record.
On the A/V unit, press Play.
Now, the Sound Recorder should indicate that it is receiving sound.
May 17, 2010 | Computers & Internet
Home AC Air Handler is making Annoying clicking sounds randomly
It sounds like the problem is with the louvre swing motor which is either opening or closing the louvre but not stopping at the end. This is due to a faulty intergrated circiut (IC) programmable chip on the PC board. Only way to get around it is to replace the board.
Jun 09, 2009 | Heating & Cooling
Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
May 02, 2009 | Acer Aspire One PC Notebook
NO SOUND ON RECEIVING END WHEN I TURN ON MY VIDEO
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Jan 27, 2009 | Computers & Internet
Sound drive is not installed or not working properly
Click Start > Settings (classic menu) or directly to > Control Panel > System,
Click the Hardware tab at the top. Click Device Manager and find the category "Sound, video and game controllers".
Click the plus sign and see if there is an Audio controller listed or anything with a yellow highlighted exclamation point in front or a red X.
Click any item mentioned in the previous paragraph and hit the delete key on your keyboard. Click Okay or yes to removing the device. Remove all items one by one that meet the criteria in the previous paragraph.
Click okay to close out of Device manager then reboot the computer.
If Device manager has no audio devices listed at all, and you are sure you actually have an audio connection on the back of your computer (sound card or integrated sound), then it is likely the sound card or circuitry has failed.
Let me know if this works or if you have additional information/questions for me.
Honest1abe
Dec 21, 2008 | Microsoft Windows XP Professional for PC
Sony STR-DE545 Receiver Logo
729 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
