Question about Brother XL-5130 Mechanical Sewing Machine
Stitching problem My machine is missing stiches when I'm sewing on knit. I'm not sure if I have the settings wrong or if something is wrong with the machine. I have lost the manual for the machine...
  • rainflood Jul 23, 2008
    The bobbin thread keeps knotting up.
  • 3 Answers
SOURCE:
I am busy knitting baby booties. At one stage the patter says k2tog yrn. Dont know what that means.
k2tog yrn, means Knit two stiches together and put the Yarn Round Needle to create a new stich
Oct 14, 2017 | Sewing Machines
How to knit this, K2. K2tog, yfwdtwice. Sl1.K1.PSSO. K19
knit 2 stiches., knit 2 stitches together, bring yarn forward then over the needle and stitch like this twice, slip 1 stitch, knit 1 stitch, then pass the slipped stitch over the knitted stitch. Knit 19 stitches
Apr 27, 2017 | Sewing Machines
I have an Elna Junior Club sewing machine and I am sewing Lycra and using the number 14 stretch stich. It just loops and bunches up underneath even though I have set everything as instructed.
Did you pre-wash the fabric? Sometimes the finish applied at the factory causes problems. Also, be sure to use a ball point needle on knit fabric. Sometimes, using a walking foot, teflon foot, or roller foot will help the fabric move smoother through the machine. It could be that your machine is experiencing a problem with the back-n-forth movement of the stretch stitch. Otherwise, here are more guidelines to review:
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Sewing Spandex Tips
Feb 02, 2017 | Elna Sewing Machines
I need to put bobin in place but Nedle dosent take the tread up
Make sure you are using a brand new needle and that is inserted correctly (there is right & wrong way!).
If it still will not pick up the bobbin thread, most likely the needle/hook timing is off. Take it for service.
Aug 09, 2016 | Sewing Machines
Tension wrong on sewing genie , bottom stich just makes a huge mess
Begin with tension setting in the middle of it's range. If the stitching improves tighten until it's perfect. Ps "Sewing Genie" isn't a real sewing machine... apologies.
Jul 19, 2014 | As Seen On TV Sewing Genie Mechanical...
Knit stitch problem
I know this is easy to say, but make sure your machine is threaded properly. And try sewing a piece of knit fabric without the knit stitch. You can still sew seams etc this way if you very slightly stretch the fabric as you sew.
Sep 07, 2017 | Singer Curvy 8770 Electronic Sewing...
My stiches keep missing a stich
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
if these suggestions don't help the the machine could be out of
time & the machine would need to be taken to a sewing machine
shop to be checked
Aug 06, 2012 | Husqvarna Huskystar 215 Sewing Machine
When I sew the back of the material thread is big loops. Is this because my bobbin is not set right?
well errr???? im a man talking to you !!!! how would i know whats wrong here???? i cant stich a button on???? but ???? me thinks its not so much the bobbin thats not set right its the needle thred tensions that are wrong there far to slack, whats happening is the needle is stiching but the bobbin is not pulling up all the exess slack, you have missed threded the sewing machine? missing out the thred tenshion bit,,that or it's just not tight,,, crank it up tighter and see if this helps pull it up more under the stiching ? if im wrong slap me !
Oct 24, 2009 | Singer Sewing Machines
I have a 12 sticher Kenmore maching that won't lay down the stiches? Everything is threaded but the thread won't go into the fabric
Check the needle, make sure it is not in backwards. Groove in the needle to the front. If you are sewing on a knit you may need a ball point needle/needle for knits.
Jul 25, 2009 | Kenmore 12102
Brother XL-5130 Mechanical Sewing Machine Logo
187 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
