Question about McCulloch MCCFH180B Electric Pressure Washer
I need to replace the nozzle on my FH180B. the
I need to replace the nozzle on my FH180B. the motor won't run, however, when I take the nozzle tip off - the motor runs fine. Where can I purchase a nozzle tip? thank you for your assistance.
  • 299 Answers
Common issue. Sounds like your nozzle is just clogged. You can try and run a wire through it to clean it or soak it overnight in white vinegar to loosen up the deposits.
Posted on May 02, 2010
Motor runs, water flows but no pressure. I hope someone has an idea to the cause.
I presume you have put a nozzle onto the outlet. There will be no pressure without a nozzle.
May 24, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Jul 22, 2015 | McCulloch FH180B - Pressure Washers -...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Replaced blower motor on my heater now it runs without top cover install cover and it flames out
This is pointing to a bad or dirty fuel nozzle, ultimately you should replace the nozzle pay attention to spray angle and GPH rating printed on the nozzle. You can try cleaning it with compressed air and a blow gun,or carb cleaner and Q-tip and tooth pick. I soak mine in carb cleaner and use the Q-tip to clean around the out side with out damaging it, and tooth pick in case there is any obvious pieces of dirt stuck in the nozzle, then blow it out with high pressure air to finish. If you have cleaned it before in this manner it may just be time to replace it. Good luck!!
Jan 11, 2011 | Heating & Cooling
Heater shuts off after we put the cover back on, after replacing the rotor, motor, thermostat, and the eye sensor
Have you tried to clean the nozzle? I use carb cleaner,Q-tip, tooth pick and compressed air.Remove the nozzle and be careful not to damage it, now soak in carb cleaner the Q-tip is to clean off the exterior of the nozzle, the tooth pick is for obvious obstructions in the ports and with high pressure air you blow both forward and backwards thru the nozzle making sure it lets air flow thru freely. If you have done this before and it still is going out once you put it together it may just be time to replace the nozzle. Pay attention to the spray angle and GPH rating on the nozzle. Good Luck
Jan 10, 2011 | Heating & Cooling
I am looking for a nozzle for a Mcculloch 1800 psi model FH 180B Can you help me? Thank you. Ken
http://ipl.ordertree.com/ipl/604/FH180B%20(DSC).pdf
There is the link to your breakdown, choose which part you need, then I would call them direct and have them send it out. Their Number is
1.800.521.8559
Let me know if this helps~!
Nov 23, 2010 | McCulloch Garden
All window washers blocked, motor runs and the washer dribble
Try carefully unhooking the hose between the washer bottle and the spray nozzle, and blowing some air through the end of the nozzle end where the spray is supposed to come out. A blow gun with a rubber tip works nice.
That should push the blockage away form the tip and back out through the hose.
Feb 28, 2010 | 2002 Ford Explorer
Rainbow vaccum power nozzle model number r-2800c is getting power but the motor does not run
If all connections are good and taking power, this simply means that you need a new motor.
Good luck
Sep 15, 2009 | Vacuums
McCulloch MCCFH180B Electric Pressure Washer Logo
150 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
