I am using a Zyair B-120 wireless LAN PC Card in my laptop. yesterday the kid flipped it over and the one of two ports that the card is plugged into does no longer work. The lights on the card do not come on. When I plug the card into the 'other' port, the lights come on (altho the 1 of 2 lights does'nt blink like it s'pose to. Even tho the lights come on,in the task bar, the ZyAir icon nor the 'two tv/internet' connection icon appear. What is wrong.??
4 Suggested Answers
shaky120
  • 310 Answers
SOURCE: belkin
Hi, your message is kinda garbled up lol. But if your Laptop is getting connected and has like 2 bars + in signal and it says you are connected it could be a few things the WEP security code you used could be wrong or you didnt put it in capitals & lowercase, as if its not exact will say connected but not let you browse, other thing it could be you need to go into internet explorer you will get page not displayed, press tools, internet options under security you need to click each picture then press default level and do it for each one then click apply then ok. then give it a try.. All the best John
Posted on Mar 05, 2007
SOURCE: zyxel zyair g-202 device driver for fedora8
I cant get the ting to work:S
Posted on Nov 09, 2008
rahul26485
  • 611 Answers
SOURCE: Zyair B-220 USB stick updates for Vista?
its shows the conflicts then you give the ip address own donn't give dhcp then conflict are not shows
Posted on Dec 31, 2008
MY Dell Inspiron 5100 Laptop suffers from Network unhealthy adapter [error 27000]. Please show any solution to get the Internet access.
If this is referring to the Lan (on board adapter -rj45 cable plug ) ..try to see if it is a driver related issue ...and to do this ..download the correct driver for ti from the support site ..and run it again ..restart and see the changes..If it is still the same it means your card is corrupted and need to be changed...(which can be a issue if it is on board) ..If you have a pci port available you can try to install a new card for network ..or use the wireless card to coonect to the net ..(install a router to the main net cord... use a desktop or another computer to make the settings and use your laptop wireless )
or ..if this error is on the wireless card ..buy a USB wireless adapter and use it ..
or ..if you are satisfied with the cable connection ..a solution can be a usb lan card ..
here is a link for examples.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=589&name=10-100%20Ethernet%20USB
This will have to be installed and will run exactly like a Ethernet LAN card ..and it will not require any intervention inside of the notebook ..
Good luck ..and please do not forget to rate the answer.
Jul 29, 2011 | Dell Inspiron 5100 Notebook
I'm using a Toshiba C 1.8 14X256M 20 CD Satellite A10 system unit model no psa10L... I do not know if I can connect to wireless lan in hotels. How do I know if my laptop has wireless modem? And if it...
I just googled "toshiba a10" and looked at the specs. It has wireless support but no wireless built in. just buy a 802.11 wireless dongle and plug it into the usb ports and away you go.
Oct 10, 2009 | Computers & Internet
I own a HP DV9000 my wireless quit working
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Jun 30, 2009 | HP Pavilion dv9000z Notebook
I have an old Toshiba 5005-S504 - want wireless connection
I looked at the specs of the laptop and it doesnt seem to have a inbuilt wireless card. Here is where I looked and if this is indeed the laptop you have, then it doesnt have a wireless card built it, http://www.pcworld.com/reviews/product/6781/review/satellite_5005s504.html
Since it has 3 USB ports, you can use one of those ports to add a wireless card. Netgear has a card.. More detials of this card are in this link. http://www.netgear.com/Products/Adapters/WirelessGAdapters/WG111.aspx
So, if you plug the WG111 in and install it, it should help work. Netgear has free 90 days support and they can help you install. Not complicated at all,if you read the manual before calling the customer.
Hope this helps Ranjit ranjit@supportminds.com
Jun 16, 2009 | Toshiba Satellite 5005-S504 Notebook
Definition of the sound card, internet lan & wireless lan
The definition of the sound card, is a chipset integrated into the main board of your laptop, in order to provide sound to your built-in speakers, or to the headphone jack on your laptop. Internet LAN (or Local Area Network) is a port located either on the side or the rear of your computer, where you would plug in a Cable/DSL High-Speed Internet connection, using an Ethernet cable (also called RJ-45). Wireless LAN is the same idea, only instead of using an ethernet cable to provide you access to the internet, it uses a wireless signal or radio frequency, to connect to a wireless access point (usually provided by a wireless router in the area). More in-depth information can be found at the following links:
Sound Cards: http://en.wikipedia.org/wiki/Sound_card
Internet LAN: http://en.wikipedia.org/wiki/Ethernet
Wireless LAN: http://en.wikipedia.org/wiki/Wireless_LAN
May 06, 2009 | Acer 4220-2346 Notebook
I have an older HP laptop with no wireless capability. We have DSL with the wireless router connected to our desktop. The only way I can access the internet is by putting in the AT&T air card. I don't want...
You can connect to the Internet using your DSL wireless router by several methods.
1. If your HP has a LAN port the you can connect to your wireless router with a LAN cable (provided you have a spare LAN port on the router.
2. You can use a USB wireless adapter to connect to the wireless router.
3. You can use a PCMCIA wireless card to connect to the wireless router.
Both the wireless USB and PCMCIA wireless adapter are approx. $50, my preference is to use a PCMCIA adapter, it leaves the USB port free for other devices,such as USB memory sticks, especially if the laptop has only one USB port.
Jan 17, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Lan card disabled
When u plug the ethernet CAT cable in the LAN card socket , so you see any light orange or green flashing on the LAN card itself.
If yes then right click on my computer >> properties >> Hardware >> device manager>> check in network adapters whether the LAN card is enabled or not
If NO the right click on it and enable it check whether it is able to receive any ip address
If u see no light at all
Then you might have to install a new LAN card on the system
Jun 07, 2008 | 3Com Megahertz 10/100 with XJACK Connector
Buying my first laptop
I am using HP dv6000, its good but costly. I will recommend you HP dv2000 its really nice it has:
  • Intel core dua CPU 2.20 GHz
  • 5 in one memo card reader
  • 120 GB HDD
  • 2 GB RAM
  • DVD write
  • Blue Tooth and Wireless
  • LAN card
  • Modem
  • Integrated Web Cam
  • 14" screen....
Its really very nice. I think it will cost in India about 45000
Thanks
Iqbal
iqbal_delphidev@yahoo.com
Apr 07, 2008 | HP Pavilion dv6000z Notebook
Pcmcia card not working pc not picking it up urgent help
Have you tried looking in your device manager to see if all is ok in there. If your PCMCIA port isn't working maybe it can be fixed from the device manager. Could just need the driver updated. I hope this problem works out asap for you.
Jan 21, 2008 | Zyxel ZyAIR B-5000 802.11b (zyairb5000)...
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
