Question about Philips Digital Voice Tracer 7655
I am not able to record ny voice at all? - Philips Digital Voice Tracer 7655
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
How to record voice calls on samsung corby S3653? There is a voice recorder,but it does not function during calls. Which software can I use for recording voice calls?
Jan 22, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How can i stope the voice mail from my phone
i dont know which set is yors.ny way, gob to messaging and delete your voice mail no.
2.you can accept BC as a contact usually
Oct 20, 2009 | Cell Phones
My computer does not recognize ny recorder as an external device
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jul 03, 2009 | Olympus VN-4100PC Digital Voice Recorder
Voice recorder
the voice key is on the side of the display screen same side as pwr hold that moz-screenshot.jpgmoz-screenshot-1.jpgto record your voice let go when finished
Feb 21, 2008 | Motorola Mobility RAZR V3
Voice recording to computer
The RCA5030 comes with a USB cable. You'll need to connect the voice recorder using that that cable to your computer and you should see the recorder appear as another drive on the computer from which you can copy files to and from. The files will be in mp3 format.
Nov 20, 2007 | RCA RP5030 Digital Voice Recorder
Philips Digital Voice Tracer 7655 Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
