Question about Waterway 1 HP 115 Volt 1 Speed Center Discharge Spa Hot Tub Pump 15" Plumbing C10115SS
1.5 hp waterway pump hooking the wries to the motor
I hooke the wires the same way as the ole on the olkd one was a aqaflo motor I hooked them the same way it blows the circut top trminal is black then white then red Like to know if the is right Tony
    President:
  • Waterway Master
  • 1,378 Answers
If it is an AOSmith motor white will be the top, high in the middle and low on the bottom. You'll need to determine if your black or red is high and the other will be low.
Posted on May 01, 2010
How to hook up pool hoses to a waterway wet end pump
front hose is intake tob or side hose is output
Aug 06, 2014 | Waterway Pool & Spa
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
230 volt waterway spa pump model#sd-20-2n22cd electal scamatic
check voltage if 220 between two hots its 220 if only 120 low voltage if 220 ok then 1st hot to L1 then 2nd hot to L2 then green to ground or case if white you might have 120 volt then see side of case of motor for low voltage wiring
Apr 20, 2013 | Waterway Pool & Spa
I have a Pentair 2 hp motor. I have 2 black wires and one white wire on the supply line. I can see where the white and one black wire go but where does the other black wire go? Other terminals on the...
I WOULD THINK THAT THE WHITE WIRE IS GROUND AND THE OTHER TWO ARE LINES (HOT) HOW TO CHECK THIS ? THERE IS A 99% CHANCE YOUR 2 HP MOTOR IS A 230 VOLT MOTOR.. SO TAKE A VOLT METER SET IT FOR SAY 50 VOLTS AC, AND ATTACH THE LEADS TO THE 2 BLACK WIRES, SHOULD SAY AROUND 220-240 VOLTS.. THESE GET HOOKED TO A-B.. WARNING IF THIS IS A TWO SPEED MOTOR, DO NOT ATTEMPT TO HOOK IT UP, IF YOU HOOK IT UP WRONG IT WILL SMOKE THE MOTOR ! OK YOU SAY HOW DO I TELL IF ITS A TWO SPEED ? LOOK AT THE LABEL IT WILL HAVE 2 RPM'S LISTED. IN THIS CASE CALL YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. HEY U , PRIME THAT PUMP AFTER ANY PUMP REPAIR !! NEVER EVER RUN A PUMP DRY... GOOD LUCK ,, NOW GO GET WET... Jay FLORIDA
Jan 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
How to wire pump
Thank you for posting your question here on Fixya.com.
Your two lines go to L1 and L2. It will not matter which is hot and which is neutral as long as you only put one line wire on each terminal in the motor. Hook your ground wire to the green screw which is usually 'above' the terminal board and your all set.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jan 05, 2011 | Waterway 1 HP 115 Volt 1 Speed Center...
I purchased a new pool pump and want to hook it up. There are 2 brass screws. Which screw do I hook the black wire to and which screw do I hook the white wire to?
It does not matter which wire goes to which post. As long as you put one on each and the ground wire on the green screw it will work fine. Be sure you select the proper voltage if your motor is dual rated. It must be set to match the line voltage present at the motor for it to work properly.
John
Oct 09, 2010 | Zodiac Pool Systems Jandy Flopro Swimming...
1031 Pool Pump 3 wires Purple, Green & black . where do the Green and Purple go?
I am assuming that you have a 220v pump motor there...the black and purple are the "hot" wires hooking to the 110 legs and the green is the "ground" hook it to the metal frame.
heatman101
Apr 20, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
The pump is wired for 110.after it runs for 3-5 minutes it starts to smoke.It can be used at 110 or 220.Is it wired wrong?
The nameplate on the side of the motor will show how the wires inside the motor are to be oriented for whatever line voltage you are supplying to the motor. The wires you bring in as line leads go to the same posts no matter if you are hooking up to 115 or 230 Volt 1~ AC power. Be certain you have your two line wires and your ground wire where they need to be and that the motors internal wires are set for 120. Most motors are shipped setup for 230 so if this is a new pump and you did not rearrange the internal connections for 115 it is likely the cause of your problem.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 18, 2010 | Waterway Svl56 1.0 Hp 1 Speed Energy...
Waterway 1 HP 115 Volt 1 Speed Center Discharge  Spa  Hot Tub Pump 15" Plumbing  C10115SS Logo
146 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
