When pushing the power button the tv turns right back off
Have a 1997 phillips magnavox tv that has worked fine til 2 days ago and then i line went through the middle of the screen only allowing to see lower half of the tv. After a couple minutes the rest of the screen would be visible also. This happened 3 times and now when trying to turn the tv on it automatically shuts off. Is there any solution besides buying a new one?
    Brigadier General:
  • 6,966 Answers
Hi barbara70,
Based on your post/description, it would appear that your TV is developing a fault in the vertical section. Chances are that it is just a capacitor normally located pretty near the Vertical IC. Physically, it would be bigger than the other capacitors within the same area. It is relatively a simple and low cost repair job.
Should you venture a DIY, pls be reminded of safety precautions when working with electrical devices. Of course this would also require a bit of familiarity with electronic components and circuitry, possible use of a DVM and definitely a soldering iron. Access to a service manual or at least a schematic diagram with voltage measurements would make the diagnosis a lot easier but not a necessity. Should you be uncomfortable going this route, perhaps your best bet would then be to seek the services of a qualified TV professional or at least somebody familiar with soldering works.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 25, 2008
SOURCE:
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
Ok my Magnavox digitla converter box has been
Something is wrong with the box, you most likely will need a new one.
Jun 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
ZN110 remote
Magnavox codes 002,009,109,118,309,402,408,502,508,510,807, 917
May 11, 2008 | Zenith ZN110 Remote Control
Magnavox tv problem
Describe the "line" for me. Is it horizontal or vertical and how long is it and how wide (or thick) is it? Keever
Mar 08, 2008 | Philips Magnavox 27MS343S 27" TV
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Will not power up ?
this is a very common problem among these projection tvs and the best thing to do is toss the damned ting out. i myself had a panasonic tv and it never turned bac on. i waited over 2 months and neer turned on. the lamp in the back has blown and its very costly to fix due to they dont make these tv no more.
Jan 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Ekse
