Question about Canon PIXMA MP600 all-In-One InkJet Printer
I Have a canon MP630 printer how do I change the paper feeder
SOURCE: problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Posted on Feb 01, 2009
SOURCE: Paper won't load. Media loaded incorrectly.
Okay.. 1st off I'm probably going to the jumped on for this... But.. I fix and/or make them work printers, computers and all sorts of electronic gear. For a living... Yes .. the manufacturer will tell you not to use alcohol to clean the rollers. but it does work. Windex (ammonia) will clean the heads at times. I also use Scotch brite pads to clean the pickup rollers. We get them in about 8x10 inch pads.
I will spay some alcohol on the end where the pick up roller is. Place the pad in normal paper tray. Most printers have a cam shaped one on the right, left or in the middle. That gets the paper moving. The pad is way to thick to actually move and will cause a jam indication on the printer. But what happens is the roller will slip on the pad and clean itself. Pretend you cleared the jam a couple of times and the printer will try to pick up the 'paper' and jam again. A couple of these and the pick up roller (cam shaped) will usually be good to go. The other option (the best) is to buy a new pickup roller for the printer. But cleaning will work for the short term. What happens on most printers is the roller gets very smooth from normal use and then won't pick up the paper for the rest of the trip through the printer. I have used a piece of fine grade sand paper, but you have to hold it so it won't go through the printer and it makes a gritty mess... Once I orderd a 'printer cleaner' from HP and all it was, was a couple of pieces of scotch brite glued to a fancy holder to match the spacing of the rollers. That's when I started using sheets of the stuff. Just pretend they are a piece of printer paper. In the worst case I have used belt dressing and then alcohol to clean most of it off. Alcohol has a tendency to soften the rubber on the pickup roller. That's why the company says don't use it. But you can by rubber rejuvenator that is mainly alcohol.. Go figure.........
Posted on Mar 21, 2009
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
  • 421 Answers
SOURCE: My Canon MP630 has a 6C10 error
You have a "Valve Cam sensor error". Usually caused by paper debris inside the printer, probably near the purge unit.
Have a ggod look inside and see if you can see any bits of paper.
Posted on Jan 08, 2010
pineworks
  • 4041 Answers
SOURCE: Paper jam in Caon MP630 printer. Can see paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 04, 2010
Testimonial: "I was able to clear the jam before receiving the response. But the response was right on the money and would have gone far to helping me clear the jam. The key was removing the ink cartridge so as to clear the way for the jammed paper. "
What does close the feeder tray mean
The Canon PIXMA iP4000 InkJet Printer has two paper sources for printing. Likely the top feeder tray is not completely closed (it is possible you do not have the printer set up to feed from both which may cause the error).
See the Quick Start Guide and the Picture Below:
Mar 06, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
How to insert papers in canon printer model no iP1300
I think Your printer problem in printer paper feeder. To resque the problem jast follow these method:
Open printer paper feeder. then open scrue and put off paper feeder. cheeck the plastic rooler. If it move tidely , try to move easily.
I think you will be relive
Thank you
Jun 05, 2011 | Canon PIXMA iP1300 Printer
Jan 08, 2010 | Canon Office Equipment & Supplies
A paper jam which I cannot see or access in my PIXMA MP630
With no other information forthcoming I turn the power off, took the paper tray out & turned the printer upside down. I could finally see some paper hidden there and gently with tweezers manipulated it back the way it went in and solved the problem Not so technical but it worked! Thanks for your help.
Dec 15, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon mp630, error 5050....what this mean?
It's mean carriage lift mechanism error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My pixma mp630 had a paper jam which I fixed. Now
The error is the APP position error. Uusually caused by foreign object in feed system or Auto sheet feeder. Check for bits of paper in the feed system.
Oct 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
MP630 print ERROR - ''There is no paper. Load paper and press OK''
You have to set up NOT "cassette"(in this case "cassette" means the front side of the printer where you are supposed to place a cd or dvd) Choose "rear tray" ! You might have changed the settings by mistake. I had the same problem. I was wondering why is the printer not taking the paper but i figured it out. Try the settings on the mini display of your printer.
Jun 10, 2009 | Canon Office Equipment & Supplies
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Canon mp780
Normally this can be caused by
1.) damaged gears
2.) damaged feeder motor
3.) damaged paper holder(the pins that grab the paper)
in any of the above cases you will need to take apart to see what the problem is.. if its the motor then you can change it..
if it with the feeder it self id suggest you consider buying a ney one,, even if you manage to change the gears or the feeder pins you may never be able to get it to pull correctly, eighter pulling twisted or constantly causing paper jams.. The choice is your but i'd say buy a new one
Jun 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
78 people viewed this question
old marine
old marine
