Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Oven will not light
Glow plug comes on but gas valve does not open
  • Kenmore Master
  • 43,501 Answers
Those things can look perefctly good and even glow and not work...check out thsi tip that I wrote it explains why they can work but not work...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 04, 2010
I have a kenmore range. The problem that I am having is that the oven will not come on and the electronic area to set the temp to the oven will not come on. The Stove Top will work but that is it. Please...
THERE IS A WHAT I CALL A GLOW PLUG IN THE BOTTOM OF THE OVEN . WHEN YOU FIRST TURN YOUR OVEN ON THIS PLUG SHOULD GLOW RED AND VERY BRIGHT, IF IT DOESN'T YOU WILL HAVE TO REPLACE THIS ITEM AND THAT SHOULD FIX YOUR PROBLEM. WHEN YOU FIRST TURN THE OVEN ON THIS GLOW PLUG HAS TO GENERATE A LOT OF HEAT TO LET THE GAS VALVE KNOW THE IT IS OK TO OPEN IF THE GAS VALVE DOESN'T GET THIS SIGNAL FROM THE GLOW PLUG THE OVEN WILL NOT COME ON
Dec 24, 2010 | Kenmore 46564 / 46565 / 465 / 6646569...
The Glow Plug is glowing, but oven will not light up.
This may sound strange but it is most often the glow plug that is bad. What happens is as the ignitor (glow plug) ages the resistance internally rises, this rise gets to a point where it limits the electrical current just enough that the valve no longer opens.
May 05, 2010 | Electrolux Ovens
Igniter comes on but gas won't light
It should glow almost a bright white. If its just an orange glow then replace the ignitor. Its probably just weak. If its weak it will not allow enough current to flow through it to open the gas valve. Good luck _MJ_
Mar 24, 2010 | Frigidaire FEB27S5A Electric Single Oven
Glow plug comes on and smell gas but no fire
That is a bad gas valve. Need too change it out. The glow bar is working but the valve is not opening.
Sep 02, 2009 | Tappan 30IN ELEC IGNa Oven
Glow plug works and is very bright
Current. When the glow plug gets hot enough the rectangular plugs draw about 3.6 amps as read on an ampmeter. The older, round ones are closer to 3.1 amps. When you think it's "orange" enough tap the gas valve with something non-conductive. If the current is close it will open.
If current is above the amps listed above and valve is not opening it's likely the valve is bad.
Aug 22, 2009 | Amana ACS3350AS Gas Kitchen Range
Turn on the burner no flame oven have light but
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
thumbs up
Aug 17, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Hot Point stove oven and broiler won't turn on
Aug 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
163 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
