Question about Oreck Cordless Speed JP8100CA Iron
My light turns on but there is no heat .It has never been used.It is a JP8100cb series
    Genius:
  • 1,116 Answers
Return the iron.
Posted on May 01, 2010
Will not heat, the start light will come on but will not heat
It is probably the thermal fuse that has blown. This is mounted on the base of the iron and requires a near total strip of the appliance. It is mounted in series with the element and looks like a metal resistor, inside a fibre glass woven sleeve. Should the thermal fuse prove not to be the problem it could also be the element itself.
Jul 07, 2011 | Black & Decker Irons
What type of water should be used for a model#JP8100CB, serial#1622072 Oreck cord/cordless iron? Tap water or distilled water? Thank you very much.
The best water to use is water that does not contain minerals. Distilled water, can be used in your iron for years without causing any buildup or clogs.
Hope helps.
May 13, 2011 | Irons
HOW CAN I OBTAIN A MANUAL FOR MY ORECK CORDLESS STEAM IRON...SEIAL NUMBER 1200661 JP8100CB?
You can download the manual from the manufacturer's web site at
http://www.oreck.com/PUG/IRONMANUAL-JP8100.pdf
Jun 24, 2010 | Oreck Cordless Speed JP8100CA Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Is there a thermal fuse in a RUSK STR8 flat iron (problem: no heat ,but LED lights ) THANKS !
yes there is a thermal fuse in series with the heating element inside the unit
Mar 19, 2010 | Irons
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
I received iron JP8100CB fot gift and I didn't get instructions, where may I get one?
I would go online and go to the company web site and try and find the customer service phone number and Im sure they can send one out to you asap. Hope I could help.
Wayne
Jun 26, 2009 | Oreck Cordless Speed JP8100CA Iron
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Oreck Cordless Speed JP8100CA Iron Logo
278 people viewed this question
Top Oreck Irons Experts
Kevin Getz
Kevin Getz
brian kossman
Level 1 Expert
Are you an Oreck Iron Expert? Answer questions, earn points and help others
