Question about Canon BJC-85 InkJet Printer
Bjc 85 vista driver??? - Canon BJC-85 InkJet Printer
  • 2 more comments
  • parogers727 Aug 26, 2008
    I am unable to scan using the bjc-85 with vista os. any help will be greatly appreciated.
  • pacoanarkia Oct 25, 2008
    no free drivers for bjc 85 or impossible to install them???
  • Anonymous Jan 05, 2009
    I neeed the driver for bjc-85 (vista)
  • Anonymous Feb 06, 2009
    I need a vista driver for Canon BJC85
As the link (http://www.usa.canon.com/consumer/controller?act=OSCompatibilitySupportAct&keycode=vistadr&fcategoryid=230&modelid=6620) in Mike's solution states, "Driver included with OS. Download not required.", i.e. Vista comes with a driver for the BJC-85 so you don't need to download one. I've just connected my BJC-85 to my new Vista machine and the printer was detected and drivers loaded automatically.
Posted on Apr 15, 2008
    President:
  • 2,351 Answers
Canon does not list a driver for Vista. You can see this at Cannon's web link here.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=6620
& why here.
There is one other way to get a driver for vista. (Maybe). Microsoft has a program that you install. It scans your PC (make sure your printer is turned on)!
It checks your PC to see if it can run Vista. (even though you have it installed).
It also will show you at the end what driver software you need for vista. Including your printer & will give you a link to download the proper driver.
You have nothing to loose.
Once the vista program has finished & you download any missing drivers, just delete the program from Add/Remove programs in your control panel. Microsoft's Vista checker program link. Windows Vista Upgrade Advisor.
http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
Good Luck.
Mike
Posted on Mar 25, 2008
Soulvisitor
  • 1113 Answers
SOURCE: canon bjc 85
Vista driver for this machine comes stnadard with vista but will not work when old xp drivers are present (or were when upgraded to vista) , remove old driver from system, connect printer,  vista should auto reconise and install.
Here is a canon link explaining Vista with BJC 85
http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=230&modelid=6620
Posted on Oct 31, 2007
  • 52 Answers
SOURCE: windows vista word 2007
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Jan 09, 2008
don_farr
  • 1018 Answers
SOURCE: will a bjc-85 work with vista?
The immediate response is that there is no Vista driver available for this printer from Canon.
However, that is not the end. Check the Vista printers and see if the driver is already built into Vista or Vista may supply a generic driver for older models of printers.
For a definite answer, you might want to call the Canon Support Center and get the Canon answer on this.
Don
Posted on Nov 25, 2009
  • 19 Answers
SOURCE: BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Posted on Mar 13, 2010
Testimonial: "You are CORRECT. I was using a new head/ink cartridge. Replaced with another one, and problem disappeared. Thank you for taking the time to respond"
I need a driver for windows vista for my printer BJC-85
They only support up to windows xp
I found this information on a forum.....
Canon does not write modern Vista drivers for a printer that old. That leaves only one other source and that's the actual Windows Vista os. If it's not included then you cannot use this printer in Vista.
http://www.usa.canon.com/consumer/co...oadDetailAc t
You have to run the Add New Printer wizard to find out if this printer is supported by the Vistamag-glass_10x10.gif os.
Aug 03, 2010 | Canon BJC-85 InkJet Printer
Installing a driver for a BJC-85 on a Dell Laptop running Windows 7 32 bit
There is no Windows 7 driver planned as this printer is obsolete on the cannon website.
It does not even support windows XP or Vista, only up to Windows 2000.
Mar 07, 2010 | Dell Inspiron 1501 Notebook
Will a bjc-85 work with vista?
Don
Nov 25, 2009 | Canon BJC-85 InkJet Printer
Trying to hookup bjc 80 to acer aspire 4730z running vista, don't have disc but am hooked up via usb.
you need the printer driver for vista in order to be able to print out. But Canon does not offer drivers for XP and Vista for bjc-80, however you can manually install the driver for BJC-85 and get the printing function going, but the scanner cartrige does not work through USB.
BR
Bruce
Oct 23, 2009 | Canon BJC 80 InkJet Printer
BJC -85 Setup Software wil not download to Vista...not compatable.....What can be done to se the Printer/Scanner on my computer with Vista.
Feb 18, 2009 | Canon BJC 80 InkJet Printer
I have window vista in my laptop and I need the driveer for a canon bjc-85 bubble jet printer
Microsoft Windows Vista shall auto detect and recognize your device.
Normally most of the drivers are aleady available with Vista Os.
Step 1:
Connect the Printer to the system
Vista will auto detect this
Step 2:
When the pop-up windows appear stating new hardware found
Try to choose one from
Maufacturer >> Canon >> Check the BJC-85
But in case if you have tried to install driver form Windows XP CD
Please delete it and/or uninstall it entirely.
I hope this resolves you query
all the best
Jan 05, 2009 | Office Equipment & Supplies
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Canon bjc 85
Oct 31, 2007 | Canon BJC 80 InkJet Printer
Canon BJC-85 InkJet Printer Logo
835 people viewed this question
old marine
old marine
