Question about ASUS (wifibralinkuay) 802.11b Wireless Adapter
Asus 802.11 a/b/g wireless adapter problem
I have asus x51rl laptop with internal wireless adapter. It see unsecure wireless network but I got message "limited or no connectivity", it sending the packets but not receiving and I switch off windows firewall, so what can be wrong? I got before windows vista and now i got win xp pro sp2 but problem is same. But my neighbor can connect with his sony vaio and xp home edition to same network. Is it make any diffrence for wireless connection from xp pro or xp home ed? Will be very appreciate for help. Filling very bad without inet. Thanks
  • hameleon Mar 27, 2008
    Hi!
    Yes you are wright about "access point (wireless signal) is not giving you a valid IP address." I installed a ASUS net4switch tool and its saying "DHCP error". Can I remotely restart DHCP server on that wireless router. It's not router in our home, I can't reboot it. Wireless card is ok because I tried another PCMCIA Cisco 801.a/b/g wireless network adapter and same error appeared.
    But my neigborough with his XP Home Edition working with same network without any problems. I'm using same laptop but I tried to change operating systems (apart of XP Home Edition ) but same error appeared. I thought is vista problem but it looks like something else. And both wireless network tools Cisco Aironet Client utility(external PCMCIA adapter ) and Atheros wireless network(for internal wireless adapter) utility showing very good signal from that router but packets not coming back :((.
    Before works very good on Vista. Maybe I need to try to install some other protocol or do you know some programs for show more information about this wireless router because it unsecure, no need any key? Many thanks in advance.
  • zou_zou000 Apr 23, 2009
    ne peut pas marcher
  • 22 Answers
The problem could be with the wireless network that you are trying to access, or it has something to do with you wireless card tcp/ip protocol.
where you using the same computer now, when you had this issue with the vista? or is this win XP pc that you have now is a different computer?
if you are getting limited or no connectivity, that means that the access point (wireless signal) is not giving you a valid IP address.
you can try to add static to your IP settings, but this will only work if you knew the IP range of that network that you are trying to access.
please provide more info
Posted on Mar 27, 2008
SOURCE:
Asus nv50
Are you telling us that you are using a Bluetooth adapter to try to connect your ASUS N50Vn laptop.to a wireless network??? For that you need a (wireless) network adapter (it plugs into an available USB port on your laptop. like the BT adapter), not a Bluetooth adapter.
Sep 05, 2014 | Adapters.com BT-0333 Bluetooth USB Adapter...
Wl-167g windows 8
The 32 and 64-bit drivers for WL-167G are linked below... what message do you get when you unzip them and run Setup to install those?
http://dlcdnet.asus.com/pub/ASUS/wireless/WL-167g-v3/DR_WL_167gV3_1005.zip
Jun 23, 2014 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
My wireless internet isnt working on my ASUS laptop. The yellow exlamation mark is on the signal bar icons and when i go into the device manager the network adapters and tunneling pseudo-interface have the...
you will need the drivers updated or replace the network card. if the drivers from Asus do not repair the problem, then i suggest a new adapter. here is an inexpensive one from eBay.
http://cgi.ebay.com/Broadcom-54M-mini-pci-wireless-WIFI-laptop-network-card-/320521450172?pt=LH_DefaultDomain_0&hash=item4aa09132bc#ht_2166wt_978
i also recommend changing the antenna whenever you change the wireless network adapter.
http://cgi.ebay.com/WiFi-Antenna-laptop-wireless-mini-PCI-network-card-/220724436636?pt=LH_DefaultDomain_0&hash=item3364339e9c#ht_2091wt_862
since you did not list the model of the laptop this is my best guess at what you will need. if you can send the model number i could double check this application for you.
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 03, 2011 | ASUS Computers & Internet
Asus U52F laptop -- 1 week old, a few days ago the internal wifi network adapter started randomly shutting itself off here and there throughout the days. Occasionally it switches itself right back on, but...
Sounds like a faulty wireless card or the card is installed with the wrong version driver.The wireless card itself sounds to be bad and needs replacing
Jan 10, 2011 | ASUS U52F-BBL9 Laptop
How can I turn on the wireless capability on my Asus G60VX laptop? the switch on the front left is on and still nothing. trouble shooting says wireless capability is turned off. it was working fine untill...
I can figure out that your laptop runs Windows Vista. Go to Control panel, then Network and Sharing centre and then go to Manage Network Connections and see if the Wireless Network Connections icon is disabled, make sure it is enabled and not connected. Try disabling and enabling it again. If still no go, try to manually turn off the wireless switch and turn it back ON. Check the light status (if any), confirm the error message too. If still, it seems not to be working, then the internal switching might have gone bad. You need to get the laptop serviced.
Regards,
Arvind
May 25, 2010 | ASUS Operating Frequency 2.4 - 2.5 GHz...
My asus n61j won't connect to the Internet using internal adapter
Hi there, I just bought a new Asus NJ series, and all of a sudden my wireless dissapeared! I FOUND THE SULOTION, well, I hope it works for you. Look on the left side of your laptop, right at the front left side is a switch/button. I think I accidentally switched it of, but now everything is working fine!
Feb 04, 2010 | Computers & Internet
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
How to change (or update) wap to wpa encryption on ASUS WIFI-B Network Adapter
With this Asus wireless B adapter even the new driver dont support WPA wireless security , because right now sicne WPA is a much newer and higher type of wireless encryption only some wireless B adapter supports that and sorry to say this wireless adapter that you have don't support it even with the latest driver so it will be better to get a new wireless G adapter that supports WPA 100% , you can get the wireless adapter from Asus or from other wireless device manufacturer like Linksys, Netgear. Dlink and Belkin....
Nov 02, 2008 | ASUS WIFI-B Network Adapter
Wireless internet connectivity problem
On an unsecured access point (not WEP or WPA) it should work.
Try here for advice http://forum.eeeuser.com/
Presumably you don't need to set a proxy in Mozilla?
Aug 06, 2008 | ASUS Eee 4G Notebook
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
See all ASUS (wifibralinkuay) 802.11b Wireless Adapter Questions
ASUS (wifibralinkuay) 802.11b Wireless Adapter Logo
1,143 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
