Question about Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor
How many Amps does this motor draw
Mion Kota 40 freshwater trolling motor
2 Suggested Answers
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
How should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
It depends on the Amp/Hour rating of the battery and the amount of current your motor draws on setting 1.
Apr 17, 2012 | Minn Kota Endura 30 Freshwater Transom...
What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
How long will a 100 amp battery run a 30 motor att 2 speed ?
The Endura 30 draws 30 amps at the highest setting (5), so it'll run 100/30 - 3.33 hours with a fully charged 100AH battery. At setting (4), it only draws 15 amps, so it'll run 100/15 = 6.6 hours. At the lowest setting, it draws 3 amps, and should run 33 hours.
Feb 12, 2010 | Minn Kota Endura 30 Freshwater Transom...
Is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor Logo
106 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
