Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
BROTHER INTELLIFAX 1840C
UNABLE TO INIT. DID THE MENU *2864. IT CAME UP PRINTER ERROR 46 INK TANK FULL REPLACED INK TANK . STILL COMES UP UNABLE TO INIT. SAME ERROR CODE. WHAT NEXT?
  • rkend1 Apr 26, 2008
    Started as can't clean. Cleared. Now can't initialize.
  • Anonymous Nov 16, 2008
    Loss power and "unable to initialize" came up. Nothing jammed. Power restored. Reset power for several minutes IAW brother site. Same as before.
Soulvisitor
  • 1113 Answers
SOURCE: Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Posted on Nov 01, 2007
checkitright
  • 1362 Answers
SOURCE: faxing
here is the manual
http://www.retrevo.com/s/brother+1840c++fax+manual
Posted on Dec 04, 2007
SOURCE: Brother Intellifax 1820c fax machine: Won't print incoming transmissions
How do you fix the error 41 that keeps showing up
Posted on Feb 14, 2008
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Posted on Apr 10, 2008
Unable to clean
unable to clean error code 46 , what does this mean model 1840c
Oct 05, 2012 | Brother IntelliFAX 1840C Plain Paper...
My MFC-3240C Brother Printer reads: Unable to Clean. What can I do
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 10, 2010 | Brother MFC-3240C All-In-One InkJet...
Will not clean servies
Brother MFC-5440CN Unable to Clean error and may work for some others.
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
May 04, 2010 | Brother DCP 115C All-In-One InkJet Printer
Clean uneable 46 brother dcp 130c printer
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
All the best Pineworks
Apr 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Mar 30, 2010 | Brother MFC-5840CN All-In-One InkJet...
Getting error message CLEAN UNABLE 46
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Mar 07, 2010 | Brother DCP-135C Flatbed Digital MFC...
Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
Error code: init unable 51
It sounds like a switch actuator is stuck down by a piece of paper in document feeder..
Unplug power cord for 10 seconds
Jul 26, 2008 | Brother IntelliFAX 1840C Plain Paper...
UNABLE TO INIT
MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Nov 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
115 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
