Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Gigaphone (sprint) 2.4 phones don't work after changing batteries
Replaced original batteries with GE 86511. The orginal battery nr is 80-5116/5017. The phones will work for awhile after chging then freeze. I remove & replace & then they'll sometimes work for awhile. If I leave in their chger they seem to get warm & won't work until the chg is down. I remove & replaCE BATTERY SEVERAL TIMES & THEY WILL START TO WORK for awhile.
Office Max tells me this is the right replacement battery.
Help
Bud
SOURCE: Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Posted on Nov 09, 2007
  • 4102 Answers
SOURCE: vtech 5808
Hi it sounds like the problem is with either the base unit board or the board on the phone.
Do you have one main phone plugged into phone socket and the other two are extra phones that just plug into mains and pick signal up off the main phone if this is the case then the problem will be with the main base unit.
So first thing i would do is check the cable to the phone from phone socket is secure and hasnt been trapped under furniture or somebody triped over it and damaged the wire.
If this is not the case then the problem will be with the base unti itself and as the waranty has ran out this usually means that the phone was only really supposed to last untill this time this is the same with most electrical unit you buy.
The problem could be something as simple as a bad solder on the main board near where the signal is sent from the base.
I would say that the actuall phone is not to fault because if the main phone was at fault then the other 2 would work fine.
If you are ok at taking electrical units apart and can test the board near the signal output on the base it might just be that the solder has failed after this time.
If the phone works for a short while before it dropps the calls then it more than likely is a solder problem the thing is it is difficult to get a spec sheet for these phones i will look and if find one let you know.
Have you tried plugging a different phone into the phone socket to eliminate a problem at the phone exchange let me know how you get on and ill let you know if i find anythnig for you ok
Posted on Dec 01, 2007
SOURCE: PROBLEMS REPLACING ONE OF MY ADDITIONAL VT2420 HANDSETS
You need to de-register the broken handset then add (register) the new handset:
http://www.vtechphones.com/vtechui/support/dsp_product_faq.cfm?product_faqID=20854
Posted on May 19, 2008
SOURCE: V tech phone---"can't connect" message
Solved it by checking the GFI outlet in my kitchen closest to the phone---That was it! problem solved
Posted on Nov 30, 2008
SOURCE: Phones going dead
buy a new battery from ebay.
just type in the search box, 80-5808-00-00
(the battery number)
You should be able to get a replacement for around $6 incl shipping.
This worked for me anyway. (Same symptoms you described)
Posted on Jan 13, 2009
My hyundai excel sprint 97 will rotate but won't start?
if spark is good and engine is good test fuel works, does it?
why gue$$ are that rich>??????
here watch scotty, its not perfect he assumes engine is good.
in fact timing belts slip every day, and no engine stated, so........
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
cranks but will NOT start.
what was changed only makes it harder , as new parts can be bad.
guessing is real bad.
guessing can very easily compound (and confound) any problem.
Jul 15, 2014 | Hyundai Excel Cars & Trucks
My cell phone wont hold a charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 28, 2011 | Sprint LG Rumor Touch Phone cover by...
My daughter has a 1994 Chrysler LHS that keeps dying. We have replaced the battery and the alternator but not sure what else to check for. We think it maybe the battery cable to cannot find an exact...
If the "dying" word here refers to engine shutting down often then its not a problem related to battery/alternator/battery cable. What you need to get checked is:
1. Fuel pump
2. injectors / FI
Please take your car to a expert mechanic who would be able to detect exact faulty component and don't waste money on guess work.
May 11, 2011 | Chrysler LHS Cars & Trucks
When i enter the charger in to my nokia 6275 the the set displyed charger not suported
i think u may changed the battery the orginal battery is replaced by u or ur frnds plesae check it out
Jan 08, 2011 | Nokia 6275 Black Rubberized Proguard...
The speaker stopped working on my htc Hero all of the sudden. I cannot hear ringers or media at all - it acts as if it's constantly in vibrate mode.
Your Speaker is burnt out just found that out with mine today. Took it to Sprint store Tech & they replaced it with a brand new speaker free of chg because I have insurance otherwise you'll be charged about $40
HTC Hero
SPRINT
May 20, 2010 | HTC Hero Smartphone
My battery dies yesterday, when I try to cherge it...
Hi, when a message comes up like that, it means your battery is not original and does not work with any charger. You need to replace the battery with an original battery before it will charge.
Take care.
May 21, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My 1501 won't turn on. I tried a new adapter but
when you pulg the original adapter, it works right? so technically there's no problem with your original adapter, maybe the problem is the battery. how old is you laptop, usually the life span of a battery is good for 1 year. try replacing the battery. hope this will help.
Apr 02, 2010 | Dell Inspiron 1501 Notebook
Very short battery life,needs to be charged every 2 or 3 days do not text. phone is used only occasionally. have had a replacement battery bt51 same as original.same results.needs better battery? phone has...
hey there.....most of the motorola phones have great battery life.....but sorry to inform you that your`s doesn`t really belong to that good-battery-life mobile models....so buying new batteries won`t help you in anyway.....so don`t spend your precious bucks on new batteries or repairing your phone without a reason.....well you can try buying a new phone...if it is economical......hope i have helped you...
AND PLEASE VOTE GOOD......HELP US TO HELP YOU BETTER .....!!
Sep 10, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Sprint Insticnt Cell iPhone is Frozen
You will need to have the lcd replaced to have it working again...take the phone to a mobile service center to have this done.
Dec 28, 2008 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Phone was operating okay, now won't turn on.
good day ! i think the problem of you phone is the battery so you need to buy a new battery to work your phone again ! good luck ! thanks !...
Sep 09, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
177 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
